Question about Eclipse EA3422 Car Audio Amplifier
Ea 3532 amp
Cannot get amp to power up off of existing wiring from previous amp...but there is power to the cable?
Double check your remote wire as i had the exact same problem and my remote wire was faulty
Posted on Jan 02, 2008
The car had existing cables in it and i tried hooking up the amp to a sub i know works. The amp doesn't light up or anything and the sub doesnt put sound. What's wrong?
Those existing cables are suspect. Start by getting power to your amp, then connect other wires, regardless of color code, to the sub. Beware of wires that look good but really are shorted somewhere. You may have to label each wire as you go along to identify its real function. You may even have to run some new wires to replace existing ones.
Sep 05, 2015 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I have alpine sps600c & am installing them in a 2001 Nissan frontier w/ 6 disc 6 speaker (2 ea in each ront door, 2 in back (crew cab). Do I wire my tweeters to existing tweeter output, or...
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Sep 05, 2011 | Alpine SPS-600C Car Component System
I hooked up a stereo system for a friend last night, and he has a 250 watt power acoustic amp, and he bought a 1200 watt amp wiring kit, is the wiring kit to powerful for the amp, because i hooked it all...
As I said in the previous post no the wiring kit is just fie. Yo uwill need to change the inline fuse and that is about it. The problem exists in how you have your subwoofers wired and what impedance is being presented to the amp. Please read my previous response to your your post.
Jan 31, 2010 | Car Audio & Video
No sound from speakers, but there is power to amp
make sure the power wire and the remote wire have voltage. at least 12 volts. make sure the ground wire is good and has a good solid ground. after that make sure the rca cables are getting signal from the radio. if you have a small speaker or tweeter you can touch the wires from the speaker to the rca cables and it should play music very quietly. meter the subs and make sure theyre ok and not shorted or bad. if all that checks out good.... the amp is probably bad. start with all the simple stuff and work youre way up. if the amp has good power and signal and good speakers then the only thing thats left is the amp. good luck
Dec 29, 2009 | MTX X702 Car Amp
Amp whine in boat
Try isolating the rca cords away from the power cords-sometimes they pickup and transmit engine noise through the amps if they are too close together
May 27, 2009 | Alpine PDX-4.100 Car Audio Amplifier
need to no what colours cables u have would be easy to talk u through it on the phone.but here we go anyway red is power and yellow is constant power (for memorey ie radio stations )back is earth. blue is remote for an amp to turn it on vier the head unit.and all the rest are speaker cables ie two greens two purple two black and two grey colour.but your peugeot electrial harness mite be different colours though thats why its better to talk on the phone about it let me no an illl let u have me number hope this helps.
May 22, 2009 | Kenwood Car Audio & Video
How do i install a subwoofer and amplifier to an exhisting car audio system
The basic would be to wire the sub amp to your batteries with the trigger/remote wire powered by your car stereo/head unit. When your head unit is turned on it will in turn power up the sub amp. Of course the sub woofer need to be wired to the amp. For the signal/audio wiring, normally, the head unit has a stereo RCA female connectors at the rear intended to be connected to external amps through a pair of shielded/audio cable terminated both ends with RCA males. Some units have a special RCA specifically for subs. Most eternal amps also uses RCA for their inputs.
If the existing car audio system has already an external amp and your plan is to add on to this, the audio/signal from the head unit could be split to provide both for the existing and the new sub amp.
If the existing car audio does not have an external amp and their are no RCA connectors at the rear of the head unit, it is still possible to connect an external/add on amp by using an adapter that connects to the speaker wires of the head unit and converting it out to line level (through RCAs) appropriate for the input of the amp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information. it would also be nice if you can post brand/model of your head unit and intended sub amp.
Good luck and kind regards.
Jan 23, 2008 | Audio Players & Recorders
Eclipse Ea 3532 Amp
reconnect the new wire or check the component inside the amp....component number are f41
Jan 01, 2008 | Eclipse EA3422 Car Audio Amplifier
Amp does not power on, flickers when cable disconnected.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 05, 2007 | Car Audio & Video
Eclipse EA3422 Car Audio Amplifier Logo
60 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
