Question about Eclipse EA3422 Car Audio Amplifier
Eclipse Ea 3532 Amp
Cannot get it to power up from old connections from previous amp, but there is power to the amp?
    Problem Solver:
  • 10 Answers
Reconnect the new wire or check the component inside the amp....component number are f41
Posted on Jan 03, 2008
What amp setting do you use when you have two passive monitors 1 ea on amp 1 and 1 ea on amp 2?
You have two monitor outputs, each controlled by a fader. Plug the amp(s) you will be using to power the monitors into these, connect the monitor speakers to the amp(s) and you're set up and ready
Oct 12, 2014 | Peavey XR 1220 Powered Mixer Mixer Powered
Where is a Mitsubishi eclipse spyder 2003 wiper relay ?
The two relays for the front [main] wipers are part of the front ECU [engine computer] and are not serviceable separately. The front wipers are powered by a 10 amp [#22 in the relay box] battery hot fuse and a 20 amp [#18 in the junction box] & two 7.5 amp [#20 & #23 in the junction box] ignition hot fuses. The front ECU is located under the hood. It sits on top of the driver's inner fender well.
Sep 20, 2014 | 2003 Mitsubishi Eclipse Spyder
No sound
What brand of reciever are you using. Most pioneers have a floating signal ground and the shield of the input at the amp needs to be connected to chassi ground. Also if you had a previous amp failure and the power ground in your old amp opened the current to power the amp will flow through the signal ground of the reciever and burn the copper trace on the circuit board in the reciever. test this by connecting signal cable shield to car reciever chassi.
Aug 29, 2009 | Kenwood KAC-8401 Car Audio Amplifier
Need help in installing amp.
depending on the power consumption of the amp u will need to run a 4-12 ga wire to the positive battery terminal. then u need to ground it with a wire connected to a clean ground like a chassis bolt. next u need preamp outputs on ur deck to send audio signals to the amp. lastly u need to hook up a remote wire to the blue wire in ur cd player harness
Jun 20, 2008 | Eclipse EA3422 Car Audio Amplifier
Looking for eclipse 32440 premier amplifier
is this a good power amp what are todays sinfo on it
Feb 10, 2008 | Car Audio & Video
Ea 3532 amp
double check your remote wire as i had the exact same problem and my remote wire was faulty
Jan 01, 2008 | Eclipse EA3422 Car Audio Amplifier
Compatibility
this is a safey feature in your amp. you are drawing too much power for the amp to put out so i shuts off when the breaking point of the total rms calue is reached. i would suggest getting a more powerfull amp, a larger ground/powerwire combo, or a farad capacitor to balancethe powerin andthe power out.
Sep 04, 2007 | Eclipse EA3422 Car Audio Amplifier
Eclipse EA3422 Car Audio Amplifier Logo
264 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
