Question about Canon LBP 800 Laser Printer
Canon LBP-800 don't print on a network
I have a Printer Canon LBP-800 that is connected to the net of my house. I use a Router D-Link DI-634M and a Print Server D-Link 301P+. I have installed Windows XP in all the machines of the net. The problem is that I cannot print. The window of impression state indicates that the port is busy, nevertheless I have followed all the steps required in the manual of the Print Server. What can I do to solve this problem?
  • abhay403 Aug 13, 2008
I have tried to print with Canon LBP-800 with 2 different print servers and no success. It seems this printer cannot be used with a print server... only with a direct connection to a computer... it supports printer sharing from windows... hope this helps...
Posted on Nov 04, 2008
I can't setup printer canon LBP 800 in the network LAN. Help me!!!
Posted on Oct 15, 2008
I have a dlink model no di-634m where i am unable to connect into net and wireless is not working .... can i get help urs to repair my dlink
Try RESETTING the D-Link back to the default settings.
Press and hold the RESET button at the back of the routerwith the power ON until the LEDs flash at the time the release the RESETbutton.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
Apr 22, 2011 | D-Link DI-634M Wireless Router (DI634M)
My DI-634m Is not giving me an IP address
Are you trying to connect to the wireless network ?
If you are not getting the IP address then you might not be connected to the wireless network.
Make sure that you know all the correct wireless settings of the router.
If your network is secured then you have the correct network key.
If you are not sure about the wireless settings of the router then you will need to access the router set up.
Click Here for step by step solutions
Nov 13, 2009 | D-Link DI-634M Wireless Router (DI634M)
I'm installing an old D-link DI 634M a friend gave me. when I have it all set with the e-net cable coming from my cable modem, I can access the web by logging in over the wireless part of the D-link (with...
You said you can get connection coming from modem directly? Or did you mean the modem is going into the wan port of the router?
Did you try all the ports on the router?
Did you check the cable?
Did you try turning off the wireless on your the pc and connecting via e-net cable?
Make sure it is not the pc or cable.
Also, check and make sure a firewall is not waiting for you to add it to the trusted sites list.
Are you getting an IP when you plug in the cable and are the lights lit up on the router and nic?
I would make sure you got a connection to those ports via another computer before moving on, and try using all the ports with a different cable if possible.
Oct 04, 2009 | D-Link DI-634M Wireless Router (DI634M)
Can I use a D-Link DI 634M as an access point?
Sure you can! As you can with any wireless router pretty much.
1. Assign the new router (AP) to an IP on your subnet that's not your existing router's IP... i.e.
2. Disable the DHCP server on the "AP"
3. Create a new wireless network on the "AP"
4. Plug your existing network/router into a LAN port
Voila! You have an access point!
Jun 21, 2009 | D-Link DI-634M Wireless Router (DI634M)
How to reset the d-link di-634m wireless router
go to this link to to reset your d-link 634m manually:
Apr 14, 2009 | D-Link DI-634M Wireless Router (DI634M)
What is the d-link part number for power adapter for D-link Di-634M router?
what is the d-link part number for power adapter for D-link Di-634M router? How can I get this?
Mar 28, 2009 | D-Link DI-634M Wireless Router (DI634M)
I need to access D-Link router from outside the network, how do i do this
- Take a visit.
Mar 10, 2009 | D-Link DI-634M Wireless Router (DI634M)
Connecting D-Link DI-634M to HughesNet HN9000
I hate it when ISPs give you devices that dictate how your network has to be setup. They should just give you a modem which give a public IP to whatever connects to it.
For this to work you have to connect the cable from the hughes box to your router on one of the four regular jacks on the back NOT the internet/wan jack you would normally use.
Set the IP of the Dlink to
Subnet mask
default GW
This SHOULD allow the router to act like a switch. I have a linksys that has an option to make it function as an access point , which is what you need for this modem, but I dont see any option for the d link you have to do that.
Hughes have a knowledgebase which may be of some use to you.
Mar 05, 2009 | D-Link DI-634M Wireless Router (DI634M)
Wireless network has disappeared !
If I understand your post/description:
1. You have both wired and wireless clients tied to the DLink DI-634M router;
2. The 1st PC is a desktop that uses Ethernet connections to the DLink and is currently working;
3. You have another (2nd) PC (a laptop?) that is connect by WiFi to the router. This is not working now;
I think that your issue may have to do with the Wireless networking of your 2nd PC, i.e. if you can access (DLink DI-634M) from the 1st PC that is wired.
Should this be the case or the scenario is different, pls post back.
Hope this be of initial help/idea. Pls post back as requested or should you be in need of additional information.
Good luck and kind regards.
Jan 21, 2008 | Computers & Internet
Canon LBP 800 Laser Printer Logo
472 people viewed this question
old marine
old marine
