PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Bootmgr is missing
By ressaskost on Oct 26, 2009
bootmgr is missing
Comments:
Oct 26, 2009
- THE LAPTOP HAVE PREINSTALLED VISTA HOME PREMIUM SO I DONT HAVE INSTALLATION CD....
Clarification Request
Posted by rjarora on Oct 26, 2009
Method 2: Rebuild the BCD store by using the Bootrec.exe tool If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps: 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. ? If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. ? If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer. PLS RATE ME >>>>>>>>>>>
Solution #1
posted on Oct 26, 2009
Not Helpful)
wizuk
Rank: Wiz
Rating: 81%, 24 votes
Find your recovery CD and use that to restore the laptop to Factory default settings
Was this helpful?
Yes
No
Solution #2
Not Helpful)
rjarora
Rank: Guru  Computer Hardware  Expert
Rating: 85%, 119 votes
1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer.
Comments:
Oct 26, 2009
- Note You can run the commands in the following procedure by using the command prompt. If you run these commands in Windows Vista, run them at a command prompt that has elevated user rights. To do this, click Start, click Accessories, right-click the command-prompt shortcut, and then click Run as Administrator.
  1. Use Bootsect.exe to restore the Windows Vista MBR and the boot code that transfers control to the Windows Boot Manager program. To do this, type the following command at a command prompt: Drive:\boot\Bootsect.exe /NT60 All
    In this command, Drive is the drive where the Windows Vista installation media is located.
    Note The boot folder for this step is on the DVD drive.
  2. Use Bcdedit.exe to manually create an entry in the BCD Boot.ini file for the earlier version of the Windows operating system. To do this, type the following commands at a command prompt.
    Note In these commands, Drive is the drive where Windows Vista is installed.
    • Drive:\Windows\system32\Bcdedit /create {ntldr} /d "Description for earlier Windows version"
      Note In this command, Description for earlier Windows version can be any text that you want. For example, Description for earlier Windows version can be "Windows XP" or "Windows Server 2003".
    • Drive:\Windows\system32\Bcdedit /set {ntldr} device partition=x:
      Note In this command, x: is the drive letter for the active partition.
    • Drive:\Windows\system32\Bcdedit /set {ntldr} path \ntldr
    • Drive:\Windows\system32\Bcdedit /displayorder {ntldr} /addlast
  3. Restart the computer.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
mouse wont work i have pressed the unlock button but still wont work
Answer
n500 touchpad not working i had not used it for about 5 months i turned it on and it seemed to be... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
