It is not on the keyboard, but on a LED light on the panel, on the hinge cover.
Hi There! It should be near above the function keys F3 and F4, just beside the speaker volume control. My pc is a Dell D630 which uses just the same keyboard. Regards!
There are always three small LEDs to indicate Caps Lock, Num Lock etc.
SOURCE: My Logitech EX110 wireless keyboard has no light indicator
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
SOURCE: Cap Lock Indicator missing
You could turn on "Toggle Keys" (which is a feature in Windows XP) that
plays a high-pitched tone when Num Lock is turned on and a low-pitched
tone when it is turned off.
(Don't worry, the sound isn't annoying or anything)
To turn on Toggle Keys:
Open "Control Panel"
Open "Accessibility Options"
On the "Keyboard" Tab put a check mark in the box labeled "Use Toggle Keys"
Click "OK"
Give it a try & see if you like it.
SOURCE: There is no light to indicate the caps lock is on
May jusy be a keyboard fault if so replace the keyboard. Also obviously you can see when you are typing in CAPITALS
