Question about SanDisk Sansa e260 MP3 Player
Stuck Screen I accidentally pressed the radio mode button in the settings screen. Now, my sansa 260 is stuck on the delete all presets option. i can't scroll down or turn off the mp3 or anything. It seems like the screen is frozen.
  • 27 Answers
It seems as thought the player itself has actually frozen. I have the same player and it has never done this to me. If you havent allready try leaving it alone in a quiet place for a day or two until it runs out of battery. Then plug it in to your PC to charge and it should be okay. As this has happend to me with other players. If it isnt however, try to resolve the issue by somehow updating the firmware. Try googling "SanDisk Sansa e260 Firmware Upgrade" and see what you can find. If there is something which looks hopeful try it, but if it doesnt work, the perhaps the only option is to return or exchange the player at its place of purchase. P.S Check the USB modes.
Posted on Jan 01, 2008
Custom programing the radio
To set Radio options, press submenu in Radio
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa e200 series is stuck on the splash screen and would not response on any or cannot be recognized by computer. Please assist
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software ( download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
Reset All
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
Recovery Mode also resets system settings when unplugged...
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
and install the software before you recover
Jun 27, 2010 | SanDisk Sansa e250 MP3 Player
My sansa clip is stuck on radio, re-setting does not work,
Can you see your screen? If not turn on your player and press the home button. Press up once and play 2 maybe 3 times to get it back on your whole playlist section. It should start playing music then.
Sep 25, 2009 | SanDisk Sansa Clip MP3 Player
You could try pressing and holding the play button to set the preset.
To delete the preset, press the options button (ie. pwr off/option) and navigate down to the "Delete preset"
Mar 05, 2009 | Sony Walkman NWZ-S616F MP3 Player
Stuck on fm radio
click the button that has the picture of a house :]
Jan 16, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
Player is stuck in a given mode
Did you hold the power button for 15 seconds until the unit resets?
Oct 31, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e140 just need some help with menus
When you power on your MP3 player it will go to the FM radio. 1. Press menu.
2. Go down once and you'll be on "Mode". Press the right button to access the mode menu.
3. You either press the enter button after accessing the menu or go down to select Playback mode (I forget which one it is).
Good Luck!
Dec 26, 2007 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
81 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
