Vacuums
Generic problem for all Vacuums
Embedded dirt finder light stuck
posted by organic57 on Dec 31, 2007
The embedded dirt finder light is stuck on red. The light stays lit even in areas that I know are clean. Is there a way to fix this or "reset' the system?
I have the same problem with the red light staying on. I've replaced filters and cleaned all accessible areas. I believe older sensing methods used an infared light but I've been unable to find what type of technology Hoover is using. The schematics don't give any clues or replacement parts.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 20, 2008
FixYa! (100)
domvac
Rank:Guru Guru
Rating: 89%, 166 votes
The Hoover uses a small microphone that is positioned in the plastic housing that the end of the hose fits into, just behind the bag compartment. What happens is that when dirt comes up the hose and hits the 90 degree corner, just before it enters the bag, the microphone picks up the sound and transmits that info to the electonics that controls the lights. Sometimes the microphone will stick and the red light will stay lit. If you take a screwdriver and give the microphone area a sharp tap with the handle of the screwdriver, this will often jar the microphone and it will begin working again. If not, it may need to be replaced. NOTE: this function does not affect the cleaning efficiency of the vacuum. Your vacuum will still work normally whether the dirt sensor is working or not. It is a totally unrelated function to the vacuum itself.
Rating Locked! (?) organic57 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on embedded dirt finder light stuck:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Kenmore 35912 / 35913 Progressive Upright...
How do I fix the brush bar so it turns?
Electrolux EL7020A Oxygen 3 Ultra Canister...
The machine has a new bag, the filters new, machine is...
Panasonic MC-V7720 Bagless Upright Vacuum
The motor is working. There is debris on the brush rollers...
Euro-Pro Shark Professional Upright Vacuum...
i need a manual to change the belt on my Shark red upright...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
