Sony Cyber-shot DSC-S730 Digital Camera
Problem for Sony Cyber-shot DSC-S730 Digital Camera
Flash does not work
By brianbilleck on Oct 26, 2009
I own a Sony DSC-S730. All of the sudden the flash will no longer work.
Solution #1
posted on Oct 26, 2009
Somewhat Helpful)
miteshanand
Rank: Guru  Sony Expert
Rating: 90%, 238 votes
Please note that:
1. You can not use the Flash when the Camera is set to Burst or Multi Burst mode.
2. You can not use the Flash when the ISO or Twilight mode is selected in the Scene Selection.
3. You can not use the Flash when mode dial is set to Movie.
Also try these steps and check:
4. Ensure that the battery is fully charged and the flash is turned ON.
Please set the Landscape mode or Snow mode or Beach mode in the Scene Selection and check if the flash is working.
5. Try initializing the Camera and check if it works normally.
NOTE: Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
6. Please press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
7. Try to power reset the Camera and check if it helps to resolve the issue. I suggest that you reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
8. If the issue still persists then the Camera requires service.
Good Luck!!!!!!!
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-shot DSC-S730
Questions and Unsolved Problems for Sony Cyber-shot DSC-S730
Do you recommend Sony Cyber-shot DSC-S730 Digital Camera?
Answer
Answer
http://www.bestlaptopbattery.co.uk/camcorder-battery/sony/HC9.htm <a... (More)
Answer
every time I try to turn my camera on a red light at the bottom dial flashes. Sometimes it turns on... (More)
Answer
Hi, i wanted ask about my rechargable bateries in my camera SONY Cyber shot DSC S730. Problem is... (More)
Answer
how do I get the date to appear onto the picture? Sony (DSC-S730)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Cyber-shot DSC-S730...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
