Sony Grand WEGA KDF-60XBR950 60 in. Rear Projection HDTV Television
Problem for Sony Grand WEGA KDF-60XBR950 60 in. Rear Projection HDTV...
Picture is OK, but colors are off and there is a
By jquilanita on Oct 26, 2009
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Solution #1
posted on Oct 26, 2009
Somewhat Helpful)
maggsises
Rank: Apprentice
Rating: 81%, 4 votes
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Was this helpful?
Yes
No
Popular Solutions for Sony Grand WEGA KDF-60XBR950
Questions and Unsolved Problems for Sony Grand WEGA KDF-60XBR950
Do you recommend Sony Grand WEGA KDF-60XBR950 60 in. Rear Projection HDTV Television?
Answer
Answer
my sony rear projection green is blurry, i pressed the fix button but the green stays the same. i... (More)
Answer
popping and cracking do not appear to effect picture but blue ghost is annoying
Answer
While watching the tv every few minutes the sound and picture will go off and after a few seconds... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Grand WEGA KDF-60XBR950...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
