Question about Frigidaire GSTF1670A Front Load Washer
How to remove agitator from Maytag A410 top loading washing machine
I just need to remove the agitator from my washing machine. I took the cap off, expecting to see a nut that I could remove to get the agitator off, but there is no nut. It appears to be just stuck on the spindle, but I can't pull it off. I tried wedging the bottom up, twisting, pulling, turning, hammering on it... but it won't come off. Is there a special tool I need, or something that I'm not seeing?
  • Anonymous Mar 29, 2014
    Took off nut, can't remove agitator. From washing machine
    Problem Solver:
  • 6 Answers
Remove the screw holding it down with a 1/4 inch nut driver.Look at the agitator from above and you will see a hole ,there is 1 only.Once you find tha follow from the hole up until you find the set screw and remove it
Posted on Jun 24, 2008
  • 1,314 Answers
Ok here's a trick i learned from my instructors for removing stuck agitators try at own risk first it looks like there there may be a set screw from looking at the part on web looks like it may be just slightly under where the tube ends and the vanes start im going to give you a web site so you can look just enter your mod num and click agitator you will see what i mean but im not there so you will have to judge ok here's the trick put a stick across the top of the tub so one end is sticking out longer than the other get two pieces of rope and run them under the agitator and over the stick tie down as tight as you can then slide the rope up as close to the middle of the agitator as you can and jerk up on long side of stick let me know if this helps 17
Posted on Jan 01, 2008
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    The washer will not go into High Spin. I had the problem before, when a penny was lodged in one of the agitators. I need to know, how to remove the 2 agitators in the washing tub, to remove any debrei
    You have to pry off the caps on the tumblers. Try not to produce any burs on them so on reinstall they dont snag the wash load.
    Once you have the caps off you take a #20 Torx driver and back out the tumbler retaining screw the SM does not call that out.
    Page 37 of the FAV6800A/FAV9800A Service Manual will detail this?
    Do you have the SM? If not join this forum and download SM 16022808 Maytag Top Load Neptune Washer Service Manual
    Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    I have a dart stuck under the agitator. How do I remove the agitator to get it out?
    pull the top cap off down insde the agitator is a bolt. it is a 1/2 inch or 7/16 inch in size. remove the bolt and lift up agitator.
    Apr 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
    Washer was filling but not aggitating,
    remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway
    Dec 12, 2009 | Maytag PAV2300 Top Load Washer
    i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
    Nov 03, 2009 | Maytag PAV2300 Top Load Washer
    Could you please tell me how to remove the agitator for cleaning on a Maytag top loading performa machine heavy duty.super size 3 speeds quiet series 100 13 cycles Thank you Bob Clark
    The agitator on a Maytag Performa comes off by removing the center post cap and dispenser by pulling on it. Locate the agitator bolt and loosen (you may need to hold the agitator in place while loosening). With the bolt removed, the agitator will lift off.
    If you still have questions, please let me know. I hope this helps you.
    Sep 16, 2009 | Washing Machines
    Agitator will not work and makes awful noise? Can this be fixed?
    Mar 02, 2009 | Maytag PAV2300 Top Load Washer
    Small items stuck under the agitator
    it should have a cap on top with a bolt underneath it that you can take loose.the top of the agitattor should pop off
    Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
    Scarf stuck around agitator.
    remove cap and ,,remove 1/2 inch agitator screw and pull straight up
    Aug 15, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
    Frigidaire GSTF1670A Front Load Washer Logo
    2,077 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
