Question about Pioneer AVH-P7500 Car DVD Player
Still not allowing me to play my DVD's..???
I have a AVH 7500DVD installed into my 2000 dodge Caravan and i tried to bypass the ocean green wire that is surposed to be wired to the emergency brake switch by grounding it or putting it on another switch and for some strange reason it still refuses to permit me to view any of my DVD...What could be the issue here??
Simply connect the green wire to the ground of your systemt
Posted on Jun 08, 2008
Pioneer AVH-P3400BH install in travel trailer....how to wire parking brake bypass?
no since u don't know what the green wire is call pioneer customer support they help me a lot
May 24, 2012 | Pioneer AVH-P3400BH Car DVD Player - 5.8...
How to bypass pioneer avh-p5700dvd
The recent pioneer DVD devices structures setup is achievable by inspecting the vehicles default wiring kits to determine the most compatible medium. The prior wires in the vehicle stereo appear mutated with attempt to extract and replace with new DVD stereo. Inspect the mutilated wires to determine the kit harness that allows connecting the new device on one end while binding to the electrical cables extended surfaces. The new stereo player makes possible connection of a multipurpose harness that solves the problems that may be thought to require bypass. Once the appropriate connection kit harnesses are acquire, the wiring should provide connectivity to speakers, tweeters, woofers and several devices as amplifiers also necessary predicted during installation else missing audio may be detected after. Refer to auto installations experts to acquire the complementary parts to attain the installations.
Feb 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Wat wire do i hook up to b able to view my movies on my pioneer avh p6500dvd
the green wire is the e brake cable if you ground this wire you can bypass the need for the e brake keep in mind that because of the type of deck you have you will need to install a switch and you will have to switch ths on and off everytime you turn into or awayfrom acc
Aug 24, 2010 | Pioneer AVH-P6500DVD Car DVD Player
How do you bypass the parking brake installation to play dvds without being in park
Well you get a resistor, 100 OHMS - 1000 OHMS or even, maybe a 12v light bulb, and connect it to either + 12 volts, or - Negative Earth, depending on how it is wired, and this will allow you to operate it...
Mar 06, 2010 | Pioneer AVH-5700DVD Car DVD Player
Parking brake
better check on your dc wiring system make sure u have fixed them tightly
Sep 09, 2009 | Pioneer AVH-P4000DVD Monitor
Im trying to bypass parking brake switch for pioneer AVH-P4000DVD. I already connected it to ground and then to power, but none of it works. I know that if i Install a toggle switch with 12volt current and...
This what you do. Connect the video wire to a power suppy and install a switch in the power wire. When you put the DVD in and the warning comes up, turn the switch on then off. This will allow you to watch the DVD without the park brake being applied.
Mar 21, 2009 | Pioneer AVH-P4000DVD Monitor
Problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Mar 17, 2009 | Pioneer AVH-P6500DVD Car DVD Player
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Bypass
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
Pioneer AVH-P7500 Car DVD Player Logo
225 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
