New product failing
Just purchased a Core 2 Duo processor E6550, Gigabyte m/b (GA-G31MX-S2), and 2G OCZ Gold Series RAM (PC-6400). Installed all items into case. Upon start-up, components start but cpu fan immediately slows & quits. I noticed that with 4-pin ATX plug in place, problem occurs. But when I remove 4-pin ATX plug & only use 24 pin ATX, cpu fan will run. Tried with 2 different power supplies (1 being an Aspire ATX-A500W). Same problem with both P.S. Is this a faulty m/b or some other problem? Also hear no system beep on start-up. If help is possible, I would appreciate it. Hate to send it all back if problem can be narrowed down. Thanks in advance. Bill
    Problem Solver:
  • 4 Answers
Well, it sounds like it is a mobo problem if u tryed other power supplys, i would test the 4-pin ATX slot in ur mo and see if it is grouding this or shoting it out, umfortualyy u will problem have to have that done professionaly
Posted on Jan 05, 2008
Intel Core 2 Duo E6550 audio drivers
on the Lenovo support pages I found three audio drivers for your system (thanks for machine details) they depend on your o/s, and can be found here (select drivers > audio, you can you can type your os in the box to give only result)
May 30, 2014 | IBM Lenovo ThinkCentre M57 - Intel Core 2...
My core 2 duo E6550 does not work on my foxconn g41mxe motherboard
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
Note the version of the BIOS program also.
Sep 25, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
I need to upate my pc or replace it to play games i have shader 2 so i know i need a better graphics card but would like to get as much ram on my pc as it will take as to the REV you lost me there i dont...
i think you mean upgrade and yes, if you want to run latest games and good performance you need to change your rig. the gigabyte ga-81915p is very limited, in case of processors used most are old like P4,celeron D and P4HT you need something that can support core 2 series.
Feb 12, 2011 | Gigabyte GA-8I915P Duo Pro Motherboard
Can 8I845GVM-RZ-C motherboard support Intel Core 2 Duo(dual core) processor?
support the Intel's Core™ 2 Duo mobile series, as well as Core™ Duo LV / ULV, Core™ Solo ULV and Celeron M processors
Good luck ! if your problem solved don't forget to vote
Dec 30, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
I want to purchase a best available core 2 duo motherboard and processor. Please suggest which is the best.
Oct 07, 2010 | Intel DG41RQ Motherboard & Core 2 Duo...
Is e intel core 2 duo e6550 compatible with 945g-m3
Yes this motherboard is compatible with the Intel Core 2 Duo E6550 processor since the maximum processor support of this motherboard is core 2 duo LGA775 Socket so everything should be fine between these motherboard and processor.
Oct 02, 2010 | EliteGroup 945G-M3 Motherboard
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to :
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
Have installed a new Core 2 Duo 3.16Ghz,6MB replacing a core 2 duo 1.86Ghz processor and my computer will not boot. My motherboard is a Gigabyte GA-945GMF-DS2. Are you able to give me any...
Here is the Processor compatability list for that motherboard:
I did not see the 3.16 GHZ processor on the list.
You can download the manual from here:
Their website is slow, but it get to the link.
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | Computers & Internet
Will not display anything when booting up.
does your motherboard has a builtin video card? u probably connected your monitor to it which supposed to be connected to your new installed video card.
Jan 15, 2007 | Gigabyte GA-8N-SLI Motherboard
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
