My boys were on the computer last night and they had a message usb powersurge, computer froze we had to unplug it and now monitor seems to be on sleep mode. power is still showing through tower, but the green light turns to yellow on the monitor. Any help on this one.
Was this solution helpful? Show your Appreciation by rating it:
Disconnect the monitor from the tower and then turn on the monitor.
If u get a msg like no input signal or check video cable then the monitor is fine. If this is the case, it could be a problem with the tower or the cable.
Have you cheked Your Monitor is plugged in? Does the socket works? If you already checked both things then your monitor have an elecritcal problem and its not easy to solve that problem unless you know about electicity currents and electric ciruits. I sggest you to call a profecional.
