Vacuums
Generic problem for all Vacuums
Hoover Elite II Model # u4689-910 Impeller...
shared by 3 users
posted by MrDIY on Dec 31, 2007
My buddy broke a window in my car and while he was helping me clean it up with my hoover he sucked up a big piece of glass that broke an impeller blade most of the way off. I removed it but now that it's out of balance it's so violent that it's unusable. I can get a replacement impeller but I can't get the old one off. I managed to twist the impeller so that it now rotates on the shaft but it doesn't seem to be threaded and it's not loosening off anymore. I've tried prying it as well but I'm afraid that I'd need to use enough force to damage the motor shaft or the motor housing assembly. I've looked at schematics and can't find anything that actually retains the impeller on the motor shaft. I've run out of ideas on how to replace the impeller in my vacuum. Please help if you've got any ideas. Thanks.
Comment posted on Jan 04, 2008
Seems like I just hadn't tried to unscrew it far enough. Threads are pretty fine on this one. Vice the motor shaft and twist the fan in the direction that it would spin; about 100 times. Viola.
Comment posted on Nov 22, 2008
Mine was threaded after all. I just needed to turn it a ton. The threads were very fine.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on Aug 05, 2008
Just posted my similar problem and just fixed problem thanks to the advice. Padded vice grips on the shaft allowed breaking friction of impeller threads and it came off easily with relatively few turns.
Burning plastic smell and major grinding sound lead me to pull it apart and see that the impeller is cracked and appears the inertia pulls the cracked parts onto the plastic housing. Having difficulty getting the impeller to budge. I'll try to twist with more force - as carefully as possible.
Best Solution
posted on Feb 05, 2008
FixYa! (100)
reddevil6
Rank:Guru Guru
Rating: 88%, 1325 votes
I have had to use a dremmel tool to cut the plastic around the shaft, you can also something sharp and a hammer to break away the remainer of the fan. There are no threads on the fan so to keep truning it may or may not get it off. Just have to watch and not damage the motor shaft and housing.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hoover Elite II Model # u4689-910 Impeller replacement:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Vacuums
I need a part for a bissell proheat turbo 2x microban...
Bissell 26506 Perfect Sweep Upright Vacuum
can't get the plastic canister off. thanks for your help.
Hoover SteamVac Carpet/Upholstery Deep...
brushes don't spin is there a belt inside to spin them rug...
Vacuums
I am looking for a valve for my powr-flite PFX1300 series....
Eureka 5892AVZ Bagless Upright Cyclonic...
Hello, I have a Eureka Boss 5890-5909 series upright. It...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
