Question about GE JES1142SF Microwave Oven
My turntable does not work.
It starts for a second and then stops.
  • mikeandbetsy Jan 01, 2008
    Thanks. However, we just bought the microwave. The turntable didn't work out of the box. Any other ideas? Thanks again.
  • 579 Answers
The turntable is driven by a motor thru a fairly long belt which is no doubt stretched and worn out. It isn't very easy to get at either being underneath the unit.
Posted on Jan 01, 2008
  • Greg Collins Jan 01, 2008
    That belt is pretty loose to start with. Concievable that it has
    fallen off in shipping I suppose. If it is that new and had that
    kind of rough handling, take it back.
How do I remove the white plastic turntable plate that moves the wheeled legs of the turntable??
inside the cabinet, there is (usually) a belt that turns that gear, you will have to unplug the unit and take off the cover to get at it, probably has some grit in the belt or such, also look for missing teeth
Jan 12, 2015 | Microwave Ovens
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
Why does NN-SN651x Microwave sometimes starts, sometimes not ?
Adj door latch switch assembly. It is not aligned properly preventing the door hooks to engage.
Aug 31, 2014 | Panasonic Microwave Oven NN-SN651B
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
The plate of my microwave own doesn't turn
Turntable motor must be replaced.
May 28, 2010 | Microwave Ovens
Shuts off after approx 5 - 7 sec. some smoke
If it stops after 7 seconds, it has a problem with the inverter.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you prefer to replace the inverter yourself, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 15, 2010 | Panasonic NN-S954WF Microwave Oven
Not Heating. Fan, turntable, light working.
I would definitely suspect the door locking mechanism in this case. If it was the sensor it would start and then stop within a short time.
The starter switch should click if you have the door open and time it for 01.seconds and press start. So that is the secon component to think of.
Nov 26, 2009 | Sharp R-930AK Convection/Microwave Oven
Panasonic microwave starts to work but stops after 20 seconds Microwaves not working but turntable goes round
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Panasonic Microwave Ovens
Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Oct 12, 2006 | Panasonic NN-T990SA Microwave Oven
GE JES1142SF Microwave Oven Logo
47 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
