Home | One For All | URC-3021 Remote Control | I need help setting a U...
One For All URC-3021 Remote Control
Problem for One For All URC-3021 Remote Control
I need help setting a URC-3220 to a sylvania?
By stephanieljo on Oct 26, 2009
DO you happen to have the code?
Best Solution
posted on Oct 26, 2009
Helpful)
digritz
Rank: Guru
Rating: 93%, 134 votes
Below is a link to a page where you can download your manual. If you need any help with unzipping it and reading it with pdf. please let me know. It's the only place I could find a manual for that model.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc3220bigeasy3&kw=URC+3220&st=&ar=&dt=&so=&pg=1&file=others/one_for_all/urc3220-manual.zip
Comments:
Oct 26, 2009
- After looking trough the manual I found that the genius that scanned it in forgot to do both sides. Which is where the codes are. However it could also mean that the only way to program the device is through the auto search. I could be wrong because only a few models are like that.
Just incase I tracked down these for sylvania TV 0054, 0030, 0171
Use these code for the input section in the manual.
This is the method for searching the remote for a code that will work. It takes a bit more time to get through all the possible codes but it works.
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH+, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching
Hope something here helps.
Let me know if not.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 03, 2009
Not Rated)
enigma_41_99
Rank: Apprentice
Rating: 0%, 0 votes
turn on your tv. press tv button on remote press set then 991 then alternate tv power button till the tv turns off. also visit www.allforone.com it has the manual
Was this helpful?
Yes
No
Popular Solutions for One For All URC-3021 Remote
Questions and Unsolved Problems for One For All URC-3021 Remote
Do you recommend One For All URC-3021 Remote Control?
Answer
Answer
how do you set up the remote to recieve the codes?
Answer
hi there does this remote have codes for onn 32inch hd tvs or do you know any that do please.many... (More)
Answer
i need the codes to program it to my orion tv and the onefor all website is useless
Answer
How do I get an owners manual or instructions for a One For All model URC4640B01?TV remote control... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For One For All URC-3021 Remote...:
Top Remote Control Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Remote Control Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
