Question about Samsung HLP4663W 46" Rear Projection HDTV
Set shuts down intertmittently
I just restart. this can happen 5or6 times over several hour period. i have pulled plug and replugged to another outlet but it continues to act up . the set was purchased11-28--04.looking for suggests.
  • 2 more comments
  • help4rtv Jan 06, 2008
    We have a samsung projection television. We have had it about 5 years but over the past several months it has been turning itself off. It seems to make some kind of clicking noises and the timer light comes on as if the timer is set. However, we have never set the timer. It was coming back on if you unplugged it and let it sit for a while. However, that is not helping now. It has been shutting itself off for several days in a row now and not seeming to stay on for any longer than a few seconds.
  • ginito Jan 09, 2008
    I have replaced the lamp and my continues shutting off.
  • digitalsanto Jan 22, 2008
    i have the same problem.
  • Anonymous Dec 05, 2008
    We also had the problem w/the TV turning itself off and on. Called Samsung and they gave us number to call for service. The tech came out and replaced three different parts (1 by 1) trying to determine what the problem was, then left w/out fixing it, but came back 2 days later and replaced another part. Still did not fix it, and I think he damaged something because it doesn't even turn on now. I called Samsung and complained that the TV was only 4 years old and they told me to fax them the original sales receipt and they would send it "upstairs" and decide if they could do anything for us. Next day they left a message that they wouldn't do anything because it was 4 years old (they knew that when they told me to fax the receipt in). I called and told them that they were saying that a $2400 Samsung is only supposed to last 4 years! They don't care. TV still doesn't work. Tech told us proudly that he learned to repair TV's on the internet!! Guess I need to buy a new TV - but not a Samsung.
Having the same concern, tv shuts down on its own 5 -6-7-8 times in a roll.GET THIS Called Samsung and they told me its the Cable Co. is at falt causeing tv to shut down on its own.BIG help they were............... MODEL# HL-P4663W. 3years old
Posted on Apr 12, 2008
  • 395 Answers
Replace the lamp part # BP96-00826A. if the lamp code on the side of the set is different replace with that lamp. you will need a tech to reset the lamp hour meter in the factory mode.
Posted on Jan 01, 2008
My Nordic Track C2200 Treadmill will stop in mid run. The timing when it happens is random. I can pull the safety tab out and put it back in and run for a bit till it stops again. Any suggestions on...
It it completely shuts down ( console shuts down then restarts) it may be a static electricity problem. Check your outlet to be sure it is grounded. Check the plug . The ground pin may have been removed.
Jan 02, 2011 | Nordic Track Exercise & Fitness
The instructions indicate to push the outer segments down with pen, etc to set timer. I can't get the segment to go down.
Generally the segments are already pushed down when you buy timer.
Instruction usually say, pull up all the segments, and after pulling up all the segments, then push down the segments for the hours you want the timer turned OFF or ON depending on timer
51ec3fc.jpgSegments on GE 15207 timer
Oct 12, 2010 | Hardware & Accessories
Model WTW6600SBO: Machine is stuck, won't spin
I'm having the exact same problem...did you ever find a solution?
Jun 16, 2010 | Whirlpool WTW6600SW Top Load
HP m7250n shuts down unexpectedly.
your power supply is faulty you will need to replace it. If you recently installed a new hardware it could be you don't have enough power to, either upgrade you power supply or remove the hardware.
Feb 27, 2010 | HP Media Center m7250n (ED842AA) PC...
I have a WD1600 Extrernal Harddrive and yesterday my kids unplugged the outlet so everything powered down instantly. Once I plugged everything back p and restarted my computer the harddrive just spins up...
The hard drive could have been irreparably damaged. The chattering sound is the heads trying to find the beginning of the data sectors and can't. The drive will shut itself off automatically after a predetermined time period.
Jan 07, 2010 | Western Digital External USB 2.0 80 GB...
GE AEW10AJS1 Window Unit A/C Shuts Off and Trips Reset.
The condenser coils may be dirty. You can wash them out with a hose or compressed air.
Jul 20, 2009 | GE AJCQ08ACB Air Conditioner
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Toshiba P30/P35 Power keeps shutting down
An overheating occured on the unit that why it's shut off when the high limit of temp. reaches.
Try to use a lap cooler, it may reduce an overheating to the unit,
Mar 06, 2008 | Toshiba Satellite P30 P35 Series Notebook
Samsung HLP4663W 46" Rear Projection HDTV Logo
164 people viewed this question
Jerry Greenberg
Jerry Greenberg
