Press and hold the widget, then a garbage can will appear at the top of bottm of the screen. Drag the widget there. It doesn't delete the widget, just moves it off that pagd.
it may solve through widget setting just remove some widgets from the widget tab on the screen 1 of ur duos phn and it can be done in the just go in display and light setting in the phone stteing menu thn widget n thn jus unmark the not reqired widget its like Setting>display and light>widget>unmark unnessary widget.....thts it hopefully it will work jus try......
hello mate, !, Touch the widget on the top left corner of ur screen 2, den press de widget u want to move 3, den a yellow border appears arnd dat widget, den drag n drop it into the bottom widget box... 4, touch done on the screen..i thnk i helped u..:-)...
Turn the phone off and on and they should restore automatically. If that doesn't work, on the screen you want a widget, press and hold the screen and a menu will come up and you can select whatever widget you want from there. You will have a number of options on the screen like shortcuts, etc, and widget will be one of them. When you press it then you will get a menu of the widgets that are supported.
Hope this helps.
You can restore the clock using the same procedure as putting any widget on your phone.
Go to the screen where you want the clock and then do a "long press" on an empty portion of the screen. Basically hold your finger on the screen for 3-5 seconds until the widget menu appears.
- Tap Widgets (it may be under a separate menu like "Sense Widgets"
- Scroll to the widget that you want and tap to select it. If there are any customization options, they will come up now. Choose the options you want and then select Done. Your widget will now be on your screen.
You can move your widget by doing another long press on the widget and dragging it where you want it and then releasing.
To remove widgets from your screen, long hold the widget, and drag to the Remove button at the bottom of the screen.
To move a widget around, long hold and drag the widget to a different part of the screen. If you want to drag it to a different screen, use your track ball while long holding the widget.
To add a widget, press on the (+) button and the select HTC Widget or Android Widget.
To remove music and wallpapers (which are stored on your SD card), you first need to connect your phone to the computer via a USB cord. On your phone, go to your notifications screen (swipe down from the top of your screen). Select "Mount" and your computer will now recognize your phone as an external storage device.
The music files are in the Music directory, and the graphics are located in the Wallpapers directory.
Remember to Turn off USB Storage by going through the notification screen again.
Hi, Basically to get rid of any reminiscent widgets (like if you were playing music and the widget still is in your desktop), just drag the widget you want to get rid off into the sidebar (the side bar will automatically expand when you drag the widget into it, and your widget will minimize and insert itself into the side bar). Now the widget is officially closed .
Open your widget bar by touching the "W". Once it's open, add all of your widgets to the home screen. Stack them from top of the screen down. that should allow you to scroll down to the one you can't get to otherwise. Now simply move that one up higher, then begin to put back the ones you don't want into your widget bar in order from bottom to top. Once you have them docked back where you want them, click the "X" to close the widget bar.
