I have a 12 inch ORION HCCA dvc, 4ohm sub. My question is this....IF I purchase a recone kit....BUT a dvc 2ohm recone kit. Can I SWAP out the 12.4 cone for the 12.2 cone and have the sub act as a 2 ohm dvc??? I have a hifonics brutus 1606 mono amp which is stable to 1 ohm. So If by simply SWAPPING the cones, I gain 400 or so more watts from my amp. Correct?? Is it possible to simply change the 12.4 for the 12.2. Thanks
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
