Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
The layers of glass between my new (6mos) LG range door are accumulating smears, streaks and a film. Sears Canada will send a technician (possibly at my cost!) to assess if it is cosmetic (?) or if there is a problem with the seal. I am waiting for the technician to advise me of possible costs for a service-call, although the range is covered by warranty. If Sears will not replace the sealed glass unit, at their expense, I will return the range for a refund. I am disappointed in the range: after 1 month, 1 burner stopped working, and now the seal is breaking down. Will let you know where this goes...
I am having the same problem. On top of the dirt, I have 2 cats in the house and there are cat hairs in between the panes of glass now too.
How can I clean this as the self clean function doesn't clean this area?
