trying to reset times on each cycle.... how to i do this? lost Manl...Trying to press 2 x botton to reset as indicated, will go to 0, what do i do after that? Don't know model. its built in.
ta HG
To reset the board so as the times will go back to factory settings.
Turn appliance on press both buttons that have the two dots under, the display will then go back to zero. Shut the door and allow appliance to reset itself. This normally takes about a minute, whilst it's doing this the pump will be running.
Hope this helps
Deep Diver
Was this solution helpful? Show your Appreciation by rating it:
i have a bosch aquasensor dishwasher which was wotking fine until the mains water was turned off in the middle of operation.Now when you turn it on nothing happens.When you press the main switch on the door no led numbers cone up like before.When you then press any of the setting buttons 2 single red led lines appear if you hold the button down but no start of any operation?
