Question about Sportline 1000 Memory watch
Sportline watch frozen
Sportine watch is frozen in chronometer mode; will not re-set no will it go to another mode. Battery?? or what could be the problem?
  • 1 more comment
  • Anonymous Jan 04, 2008
    This happened within one week when I bought this, so I returned it. They exchanged it, but it happened to the second one. I bought a new battery for the second one, and it worked for about 3 weeks. I am now on the second battery on the second watch and it has happened again.
    The watch freezes and won't go so anything.
  • Anonymous Jan 15, 2008
    The alarm does not want to stop.. Help
  • theodore1 Jan 15, 2008
    Alarm does not stop. Help !!
Electronic Tech for Government & the last thing you want to do is try to fix it yourself. The watch is a dual unit with the power supply (battery) encased by plastic & a steel unit case wrapping itself around that. To complicate things there are two circuits connecting pad (sensing unit) built THRU the power unit (as springs). There is a rubber piece that makes the circuit for pulse mode from the case to the watch & that is tricky to place for sensing unit to work (the whole purpose of having this sport watch). Replaced mine for $4 but it was a surprise to find it THAT complicated.
Posted on Apr 03, 2009
Uggghh, same problem here..waht a piece of @#$#@@
Posted on May 10, 2008
My watch completely froze....and its beeping and it won't stop and its driving me crazy! It worked great for a few months...actually was my favorite christmas gift...but now has to be scrapped because it decided to randomly freak out on me! What a piece of ****! Don't buy it! Sportsline SUCKS!
Posted on Mar 23, 2008
Mine is screwing up also after about 1 week.
Sucks 4 me since i don't have the receipt and bought it at target US--I'm in Canada!
Posted on Jan 09, 2008
  • 3 Answers
I think it's caused by static. Poor watch design, so this problem will keep on repeating. And repeating. Buy another brand and avoid Sportline. Luckily I only paid $20 for mine.
Posted on Jan 06, 2008
How do I reset the correct time on this watch?
That depends on the make / model of the watch.
Most mechanical watches, and some battery operated analog watches have a knob that can be pulled out half way, to set the date, and all the way, to set the time.
Most digital watches have at least two buttons: one (I'll call "A") for setting the mode, and "B" for incrementing some value.
Typically, one presses A briefly, to cycle the display through "clock, calendar, alarm, chronometer etc".
By holding A for a few seconds, likely, something will start to flash. This indicates setting mode. Pressing A briefly again, will cycle through seconds, minutes, hours, day of month, month, and possibly year. (perhaps in opposite order). Pressing B will increment whatever number is flashing. Holding A again, will save any changes, and return the watch to normal mode.
Mar 17, 2015 | Watches
I cant change the time on my sportline solar watch 8105 help
Press "MODE" and above it "SET" and it should help you re-set the time correctly.Hope this helps!
Mar 07, 2011 | Sportline 1000 Memory watch
We bought a sportline solar watch that has a light mode and rerset and st/stp function mode we want to set the time but don't know how? Help please
mcdevito75 here, I see in your question, SOLAR if that means the watch is operated from the sun"s energy, you first have to get the watch going (ticking) before you can set the time, Instead of a Battery your watch has a capacitor that holds onto the sun"s energy and releases it, makeing the watch go (tick). After the watch goes, you need worry about 2 buttons, MODE & SET. Press MODE and see display Flashing, now press set to set each function, (hour, minute etc.) presss MODE after ecah function is set to move on, once all functions are set, press MODE for steady display, also if thew watch is new, look for a small piece of plastic just under the crown, remove that plastic and push crown down to start watch. Hope this helps.
Jul 04, 2010 | Watches
Setting the time
On the C9 Fast Wrap Strap digital watch, press and hold the "LAP/RST" button until the display shows "SET" then release. Use the "MODE" button to switch between second, minute, hour, etc. Use the "ST/STP" button to change. Press and release the "LAP/RST" button to exit. The Sportline might be the same or similar.
Mar 15, 2010 | Sportline C9 by Champion Fitness 910 Watch
Sportline 915 heart rate watch 2nd mode questions
the number is for your age, the F or M is for female or male. this will give a more accurate percentage for your heartrate
Jan 12, 2010 | Sportline Watches
Chronometer won't start
Not sure this is worded right. A chronometer is watch that has been certified by a Swiss organization to keep time within a set +/- seconds per day in several positions and temperatures.
A chronograph on the other hand is a watch that has push buttons on the side for starting/stopping/resetting a set of hands to mark time elapsed.
If this is truly about a chronometer not starting it is either a broken part or needs cleaning.
If it is about the chronometer not starting most likely if it is a mechanical watch the pusher is stuck or broken or a lever is out of place or bent. If the whole watch does not run then it could be a broken mainspring.
If it is a quartz chronometer it could be a bad battery or if the battery has been changed it is most likely the person that changed the battery has damaged one of the coils and or circuit.
A qualified watchmaker can help with any of these problems.
Hope this helps,
Ken Kotoski
Yellowstone Watch Inc.
Nov 28, 2009 | Breitling Watches
Sportline watch setting time???
With the watch in time mode, press and hold the mode button for 4 to 5 seconds until it beeps and the digits start to blink. Then press the mode button again to advance through each setting. When finished press and hold the mode button to exit the setting mode.
Mar 15, 2008 | Sportline 1000 Memory watch
Time Change
Using a Sportline but I'm an hour off with daylight savings time. How do I change the time, I can't figure it out. Can
Mar 10, 2008 | Sportline Big Digit Watch
Sportline watch
Love my watch, Was placing it on wrist, time correct, pressed button to test pulse and everything went blank. Pressed reset button, with no effect. It has a high pitched whine when placed at ear.
Does this mean I need a new battery, and where is that done, so I don't mess it up.
Appreciate any help as I don't have the instruction book either,
Feb 22, 2008 | Sportline 1000 Memory watch
Sportline 1000 Memory watch Logo
667 people viewed this question
Top Sportline Watches Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Sportline Watch Expert? Answer questions, earn points and help others
