WD portable HD light is on when plug in to USB port. Computer fails to recognize the device.
Serial Number: WXE507155627 Model Number: WDXMS1600TN
Comments:
Oct 26, 2009
- Has this drive worked before in this or any other computer? the drive worked for 2 years until yesterday, primarily with computer.
Try looking for it this way... Got Administrative Tools>Computer Management >Storage >Disk Management - drive does not show up.
When I put my ear on the drive when plugged in,it sounds like small rocks pinging around (but I don't know what it sounded like before)
Has this drive worked before in this or any other computer? Try looking for it this way... Got Administrative Tools>Computer Management >Storage >Disk Management and see if the drive appears in the table. If it shows up there, tell us what it says about the drive ie. Healthy, Active, etc.
There are a few reasons this would happen, The options are a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
Was this helpful?
Yes
No
Popular Solutions for Western Digital WD Passport
Western Digital WD Passport 250GB Portable Drive 250 GB Hard...
is there a Western Digital storage solution compatible with Macs and PCs. We mainly have Macs and...
(More)
is there a Western Digital storage solution compatible with Macs and PCs. We mainly have Macs and want an external backup solution / hard drive. We also want portable hard drives that can also work on a PC. Can you make suggestions please. Do you have any feedback regarding Macnally v Western Digital. Thanks heaps, Tara
I purchased a passport elite and it is showing an error message on my laptop stating it is not...
(More)
I purchased a passport elite and it is showing an error message on my laptop stating it is not compatible. I have a toshiba vista system
