Samsung LN-T4061F 40 in. HDTV LCD Television
Problem for Samsung LN-T4061F 40 in. HDTV LCD Television
How do I get rid of purple and green wiggly lines?
By davisr_2 on Oct 26, 2009
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while. The purple and green lines still appear, although not as bad. The purlpe lines appear in a white background and green on dark backgrounds.
Solution #1
posted on Oct 26, 2009
Not Rated)
toddthetvmd
Rank: Guru
Rating: 92%, 23 votes
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Was this helpful?
Yes
No
Popular Solutions for Samsung LN-T4061F 40 in. HDTV
Questions and Unsolved Problems for Samsung LN-T4061F 40 in. HDTV
Do you recommend Samsung LN-T4061F 40 in. HDTV LCD Television?
Answer
Answer
samsung lcd 40" tv wont turn on it just makes a clicking noise
Answer
keeps trying to turn on after a while it eventually will, seems to be getting worse
Answer
samsung lnt4061f there is a slight shadow of what looks to be about 3 inches wide and about a foot... (More)
Answer
Our samsung LN-T4065F works for awhile then the screen starts blinking. there is no set pattern to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung LN-T4061F 40 in. HDTV...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
