Question about Lexmark P315 Photo Printer with 2.5" LCD Display and Card Readers
NO POWER THE PRINTER IS PLUGGED INTO THE MAINS&ALSO INTO THE POWER PACK AT BACK OF PRINTER,BUT THE PRINTER WONT TURN ON.
  • ansell Jan 02, 2008
    Printer P315 plugged in but no power at all.
I wondered if perhaps the power pack at the back has gone. Mine has done the same, wondered if you can replace this power pack
Posted on Jan 02, 2008
My kids were playing the Wii & the power went out. Now I cant get it to come back on. Any ideas?
hi the only real thing you can try yourself is resetting the power pack, to do this you need to unplug it from the mains and also unplug it from the wii, leave both ends unplugged for at least 5 minutes, doing this activates the reset procedure inside the power pack, then plug it back in and give it a try.
if it still dont work then the chances are you need to replace the power pack, the chance is the power pack got fried and not the wii as the wii only needs 12volts from the power pack so this shouldnt cause any harm as the power pack reduces the power down to 12v so if it wont work try replacing the power pack or try using a friends power pack just to test it with.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 05, 2010 | Nintendo Wii Console
I have the Plug going to the wall and confirmed power at the outlet. I have the UBS back to the Computer and plugged into the printer and it will not turn on at all. Its a Year old at most and havent used...
I see a power supply issue here. Looks to me your printer power pack is gone bad. You need to confirm this by trying another similar power pack with the printer to be sure. If the printer is portable take it to the store or technical personnel to try another power pack with it. Once confirmed you may have it replaced.
Good luck & God bless!
Nov 30, 2010 | Canon MX700 Office All-In-One InkJet...
My printer wont work. Its on and everything is plugged in correctly why wont it print it was just fine yesturday.
Turn the printer off. Disconnect the power-cord from the wall-outlet.
Turn the computer off.
Reconnect the power-cord & turn the printer on.
Turn your computer on, and try again.
Nov 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Canon pixma mp780 printer will not turn on!
It's possible that the printhead has burned out and in the process it's blown the printer in the process.
You can try one trick that has worked for me in the past but it's by no means guaranteed.
IMPORTANT:
- Disconnect the printer from the mains/power socket!
- Remove the cartridges and printhead
Work out how to remove the left panel (left when looking at front) and then identify the power pack which is like a module that plugs into the printer.
Into this power pack goes one or two small internal connectors which you should disconnect, wait 10 seconds and then reconnect.
Push the power module back into position if you've had to release it, and then try plugging the printer back in to the mains/power-socket and try turning the printer on.
If it DOES comes back online, you should get a brand new printhead ASAP.
IMPORTANT: DO NOT use your old printhead as it will blow the printer or any other printer that it is installed in.
If it doesn't come back on then it's toast and it's time to look for a new printer.
I suspect you will find the printer is dead but if it does come back online you'll have dodged a bullet that took my MP750 and iP4000 to printer heaven. The fix above worked for a couple of iP4200's and an MP500 so it could still be ok.
Good luck.
Mar 03, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Turning on i guess
It should work OK once you plug it back in. Note there are three places to check the power connection.
- The power pack has to be inserted firmly
- the cord that goes into the power pack
- the cord into the wall - be sure to check the wall outlet with a lamp or something to make sure it's not an overall power problem/breaker, etc.
Steve
Sep 11, 2008 | Lexmark X5470 All-In-One InkJet Printer
My toshiba laptop l10 281 has stopped working it was working perfectly and was shut down properly wen i went to turn it on again today it wont go it wont even light up please help!! thanks in advance john
If nothing at all works then perhaps you have no power to the system.
Check that the powerpack is getting power (does it hum or get warm when plugged into the mains socket?) Check all connections to the power pack and back of laptop.
Try taking the battery out and powering up on only the power pack
Do you know anyone with a similar laptop that you could swap power pack with?
Jun 30, 2008 | Computers & Internet
Hi-- This is actually a problem with the Canon LK-51B battery pack that goes with the iP90v portable printer. We've charged up the battery pack and all the lights have gone out, indicating full...
electronics should not be relied on to realy confirm u need to use a second battery pack to connect ur printer n see if the same thing will occure. i guess the battry inside d pack may be dead even though its a new one.
May 24, 2008 | Canon Office Equipment & Supplies
Printer wont power up.
Try different wall outlet if issue is same .It either printer fualt or its power adpater fualt...
Nov 15, 2007 | Lexmark P4350 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
