Question about Philips GoGear HDD1830 MP3 Player
2gb playlist? how do i make a ply list on here
  • 8,596 Answers
Re: 2gb playlist?
You can make the playlist on Windows Media Player frst, and then drag it over to the sync tab for the goGear. Or, you can left click on the GoGear icon in Windows Media Player, and click on "Playlists".
-Tha Mp3 Doctor
Posted on Feb 11, 2008
0 characters
3 Points
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
On my Gogear Raga 2GB I can't make a playlist. (SA2RGA02). With WMP I can synchronise the music, but there's no playlist on the device. All the music is stored in different folders on the Raga and not in...
Sync all the songs you want onto the raga via 'songbird'.
Stay connected, then go to windows explorer, identify your device. Then in 'Music', make folders for your playlists. Manually transfer (drop and drag) your songs to the required folder/playlist.
When using the raga use the 'folder' option. Works as playlists.
Jul 10, 2010 | Philips GOGEAR SA6045 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
How do I erase the playlists on my sansa fuse 2gb player?
connect your mp3 player to your pc... find those unnecessary playlists and just delete them... if it doesnt get deleted then try to format the player and make it fresh... add playlists that u wish later :)
Sep 26, 2008 | SanDisk Sansa e200 MP3 Player
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
52 people viewed this question
Top Philips MP3 & Digital Media Players Experts
 Mike M
Mike M
Pieter Vleeshouwers
Are you a Philips MP3 and Digital Media Player Expert? Answer questions, earn points and help others
