Question about Zenith DVC2200 DVD Player
Was playing DVD, paused it, then won't acknowledge any commands
We were watching DVD, everything was working perfectly. We paused it due to a brief phone call. Once the phone call ended we tried to unpause the movie and nothing. We tried to stop and start it, again nothing.
Please advise what the best method to do it. This DVD player is rarely used. At least advise how to get it to release the DVD.
Your help is greatly appreciated.
Thank you!
By the way, Happy New Year.
  • Anonymous Jan 19, 2008
    I have the identical problem with my Zenith DVC2200C.
    President:
  • 4,402 Answers
I think a belt or gear is slipping, you will have to open it and look inside.
Posted on Feb 11, 2008
Luz marcada con el numero cinco?
2003 Jeep Liberty- Reading Engine / Diagnostic Codes ...
? 1:13
https://www.youtube.com/watch?v=pGrPBBzp7wE
Jan 6, 2013 - Uploaded by DeathScouter
2003 Jeep Liberty- Reading Engine / Diagnostic Codes ..... error code will flash 2 times, brief pause, flash 1 time, pause, flash 5times, pause, ...
2005 Jeep Liberty possible cause of P0442 error. - YouTube
? 5:26
https://www.youtube.com/watch?v=2ba-gH0gadg
Dec 21, 2014 - Uploaded by TheBGravit
While replacing a bad fuel pump I believe I found the cause of a P0442 Error code. I was able to repair the ...
Jeep Liberty Questions - Cylinder Misfire code - CarGurus
www.cargurus.com > Questions > Jeep > Liberty
CarGurusMay 27, 2009 - My jeep Liberty 2009 does the same the Dashboard showed a code of cylinder .... i have a jeep liberty 2006 with the # 5 cylinder misfire. i replaced the sparks... I have a 2005 Jeep Liberty 6 cylinder, engine light came on scaned the ... 2002 jeep liberty camshaft posistion sensor error code p0340 5 answers.
Check Engine Light/Misfire Due to Intake Valve Locks ...
repairpal.com > Problems > Jeep > Liberty
Recently got a second hand 2005 Jeep Liberty Sport. Everything worked fine ... #5intake valve seat dropped and held open the intake valve. 2008 Jeep Liberty.
OBD-II Trouble Code: P0305 Cylinder 5 Five Misfire Detected
www.obd-codes.com/p0305
Dec 08, 2015 | 2005 Jeep Liberty
I can't get subtitle to turn on. Zenith DVD player to play movie with Subtitle
What you want is Closed Captioning. It has nothing to do with subtitles. If you turn off the speakers in your TV, the CC should appear after a brief pause. If your TV is not equipped for CC, this approach won't work
Nov 11, 2012 | Televison & Video
PLAYER SWITCHES OFF WHEN PLAYIING VHS TAPES
check any mechanical failure in the vcr unit. like tape won't work properly might some obstruction or plastic broken.
Sep 15, 2012 | Toshiba DVR660 DVD Recorder/VCR
No video sound from lg dvd writer when playing dvd movie. player will play cd sound. what is the problem.
I had the exact same problem with my LG model GH22LP20 DVD drive. This is how I solved my problem:
I finally solved this problem. It was a Cyberlink software problem; specifically the software bundled with my DVD which was a Cyberlink Suite w/ PowerDVD2_bing.gif 7.0.
After going 3 - 4 rounds, via email, with Cyberlink tech support in India I finally got them to put down their "100,001 mindless ways to solve a software problem" manual and they emailed me a link to download a slightly newer version of the software; it was Cyberlink Hi-Def Suite, w/ PowerDVD 7.3.
I uninstalled my bundled software, and installed the newer software they gave me. After installing the newer software everything worked perfectly. If you're still having problems and have the same software version I started with, keep bugging Cyberlink tech support (be patient and diligent) until they acknowledge it's a software problem and send you a download link for a newer version. Good luck!
Jan 30, 2010 | LG GH22LP20 DVD±RW Burner
CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Dec 28, 2009 | Dell Dimension E521 PC Desktop
We had no control of the DVD that we watched last night. No pause, fast forward, etc. Tonight, trying to watch another DVD and the one from last night continues to be playing and will not eject. Neith
Sometimes when you unplug the set ffrom the wall power or a while 1-2 minutes, and then plug it back in the problem will resolve itself. The DVD may eject. If it does, check it for damage, warping or dirt. If this does not fix it- you probably should take it to a repair center.
May 27, 2009 | Televison & Video
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Freezing?
any commercial films are written to what's known as dual-layer DVD discs, which are like two DVDs sandwiched together. Movie studios try to pack as much cool stuff as they can onto a DVD, so by the time you add movie trailers, documentaries, and other special features, the amount of space necessary far exceeds the 4.7GB capacity of a regular DVD disc. Using a dual-layer disc expands the capacity to 9.4GB, which is enough to hold the movie and many extras, depending on how long the film is. What you seem to be experiencing is a problem related to the DVD player changing layers (when it must adjust the focus of the laser to read the second layer of the disc), which is usually indicated by a brief pause during playback. In the early days of DVD, many players had difficulty during the layer change, which could cause the DVD player to lock up during playback. In other cases, a badly formatted or damaged disc could be the culprit, so you should check the condition of the DVDs that are giving you problems. Since you mentioned that sometimes they work, your problem could stem from a scratch or a fingerprint. But, if the condition of the DVD is flawless, you may have to consider getting your DVD player repaired, replaced, or exchanged (since you mentioned it was new). Since it is a portable DVD player, you may want to try running the DVD player when it is plugged into an AC receptacle. This will at least rule out any relationship to the battery, though a remote possibility. But, portable devices do strange things when its battery is low. Many commercial films are written to what's known as dual-layer DVD discs, which are like two DVDs sandwiched together. Movie studios try to pack as much cool stuff as they can onto a DVD, so by the time you add movie trailers, documentaries, and other special features, the amount of space necessary far exceeds the 4.7GB capacity of a regular DVD disc. Using a dual-layer disc expands the capacity to 9.4GB, which is enough to hold the movie and many extras, depending on how long the film is. What you seem to be experiencing is a problem related to the DVD player changing layers (when it must adjust the focus of the laser to read the second layer of the disc), which is usually indicated by a brief pause during playback. In the early days of DVD, many players had difficulty during the layer change, which could cause the DVD player to lock up during playback. In other cases, a badly formatted or damaged disc could be the culprit, so you should check the condition of the DVDs that are giving you problems. Since you mentioned that sometimes they work, your problem could stem from a scratch or a fingerprint. But, if the condition of the DVD is flawless, you may have to consider getting your DVD player repaired, replaced, or exchanged (since you mentioned it was new). Since it is a portable DVD player, you may want to try running the DVD player when it is plugged into an AC receptacle. This will at least rule out any relationship to the battery, though a remote possibility. But, portable devices do strange things when its battery is low.
Jun 12, 2006 | Cyberhome CH-DVD 300 DVD Player
Zenith DVC2200 DVD Player Logo
117 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
