Question about Chaintech 7NJL3 Motherboard
Random freezes XP 2x256 Ultra RAM. Added 2nd stick of RAM yesterday. Was just slow but now locks up for no apparent reason on a random basis. The RAM would not work at all with one stick in the DDR3 slot per the manual. Works good and is fast installed that way except now have the lock up prob since adding the other stick of 256K RAM. Also having some problems with applications not responding or just quitting in the middle of what I'm doing. ???? Get the blue screen suddenly and have to reboot as well. Boots right back up and works fine unitl the next lock up or blue screen appears. All seems to be increasing in frequency.
  • W4833 Jan 01, 2008
    Thanks a bunch. I'll give those a try. I was thinking about adding another gig of RAM but want to make sure there's no problem lurking out there that would annul the effect before I do.
    Sergeant:
  • 263 Answers
Blue screen means you have problem with your windows software or memory if you don't fix this soon it will not work any more until you reload the windows check your memory cards for good attachment
Posted on Dec 31, 2007
What's its ram
It stands for Random Access Memory and it is where temporary data is kept that your computer needs to run certain programs. It can also be a reason for a computer to run slow. You should restart your computer occasionally to clear out the RAM and keep it running more efficiently.
Sep 18, 2015 | Computers & Internet
Ddr ram
It will take up to 1GB of 133-megahertz (MHz) synchronous dynamic random-access memory (SDRAM) ...
2 X 512MB 133-megahertz (MHz) synchronous dynamic random-access memory (SDRAM) chips
Aug 10, 2012 | Dell OptiPlex GX240 PC Desktop
The laptop keeps buzzing and freezing at random times.
The problem may be with the hard drive, sub out the ram one at a time and test each time just to be sure it is not something simple, if there is no change! the hardware is suspect.
Apr 05, 2012 | ASUS K50IJ Notebook
I have an Acer Z5700 that has started freezing at random times for no apparent reason. I have tried to re-install to factory state, all to no avail. I even get the blue screen at times in Safe Mode.
The blue screen should give you pointers as to what the problem is, have a look in the event viewer to see if there any recurring faults, from what you describe I would suggest either the hard drive or the ram needs replacing.
May 05, 2011 | Computers & Internet
My HP compaq nx6110 windows xp sp3 hangs at boot
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. If the described symptoms also happen on your laptop. If you do experience random freezeups or slow DVD you're facing the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Nov 14, 2010 | HP Compaq nx6110 Notebook
Hp compaq will not boot, sticks at hp invent screen with F10
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. See if the described symptoms also happen on your laptop. If you did experience random freezeups or slow DVD you're dealing with the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Oct 26, 2010 | HP Compaq nx6110 Notebook
Hi Guys, i have been trying to reinstall windows xp profressional on a celeron PC but when i go into the setup mode the screen displays the message as "Do u want to recover data" 'yes or no' and...
Well, seems like your windows totally crash!!
You need to reinstall it with option"No" when recovering data pop up.
You need to install it using the first boot option, insert the Windows CD, and booting using the CD first.
After enter the windows XP setup menu, make sure you format the drive for Windows installations.
Hope it works
Feb 22, 2010 | Compaq Presario C552US Notebook PC
Hi there. I have an HP a6500f. Came pre-loaded with 4GB RAM. Worked fine for a year then started freezing/restarting/BSOD randomly. Ran memory diagnostics and got a BIOME-1 error with both sticks, but...
Try manually setting the ram timings in bios but....
i would think its a motherboard issue too by the sounds of it. find one that has a similar specification and fit it, I will suggest one if you need me to, just give me a list of the hardware you have installed on this current machine
Jan 14, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Video freezes on hp e9105z on a random and intermittent basis Nvidia gt 120 video card
Test these three things:
1 - GPU could be overheating, can you swapp your video cards with a known working card?
2 - PSU could be bad, again try swapping with known working PSU, makes sure card is recieveing proper input power.
3 - I have seen a bad ram module do this before also, but, try reseating the RAM, run memtest86 for errors
Great testing tool, HIRENS bootCD
http://www.hiren.info/pages/bootcd
Oct 22, 2009 | HP Pavilion a6700f PC Desktop
Compatability of Memory Upgrade
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Thanks
Bhaskar
Jun 04, 2008 | Acer Aspire™ T180 PC Desktop
Chaintech 7NJL3 Motherboard Logo
88 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
