Brother MFC-210C All-In-One InkJet Printer
Problem for Brother MFC-210C All-In-One InkJet Printer
Unableto clean
By ninatatit on Oct 26, 2009
my printer unableto clean
Best Solution
posted on Oct 26, 2009
Helpful)
cene765
Rank: Guru  Brother Computer Hardware  Expert
Rating: 89%, 398 votes
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then'menu' one by one...
2. Press the arrow up or down to go to'maintenance 80'.
3. Press 'mono start' several times to go to'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered thiscombination, the purge numeric value will be reseted to 00000.
Comments:
Oct 27, 2009
- Sorry the procedure is wrong.That is correct:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
annoying cannot clean message.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Brother MFC-210C All-In-One
Questions and Unsolved Problems for Brother MFC-210C All-In-One
Do you recommend Brother MFC-210C All-In-One InkJet Printer?
Answer
Answer
it says unable to print see chapter troubleshooting and maintenance what should I do
Answer
my Brother MFC5840CN all-in-one printer is saying "Unable to clean" but i cannot see... (More)
Answer
Brother mfc -210c printer scanner fax copier. The printer is working and the scanner was working -... (More)
Answer
have a brother mfc 210 - scanner work fine before and error messaage unable to communicate with the... (More)
Answer
Unable to clean message fromBrother MFC 210C
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Brother MFC-210C All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
