Question about Zenith C27V22 27" TV
TV set shuts off after plugging in VGA cable
I just bought a VGA cable to deliver the picture from my Xbox 360 in a higher resolution than the component cable will allow. However, when I plug in the cable to the 15-pin RGB port on the back panel, the television power just cuts out.
It doesn't matter what input channel the set is tuned to, the tv powers off as soon as the connection is made, and I cannot turn it back on until the cable is removed. The first time I plugged it in only the picture cut out, with subsequent attempts to connect the cable resulting in loss of power.
I don't think it has anything to do with the Xbox being set to progressive or standard scan modes, since the power to the TV is out even before the Xbox is turned on. I've never utilized the RGB port before, so I have no precedent for dealing with problems of this sort.
On an unrelated problem, this TV is supposed to support both 480p and 1080i HD formats from the Xbox 360, however, when I switch the Xbox from 480 to 1080 the display intermittently turns on and off. This happens using the component cables, which was my reason for buying the VGA cable - I thought since it wasn't supporting fully the 1080 format via the component cable, it would with the VGA cable. Any thoughts on either or both of these problems?
0 characters
1 Points
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
Nov 20, 2015 | Sanyo DS31590 31" TV
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
Sep 23, 2011 | RCA F25254GY 25" TV
How do i hook up my sharp 27f543e to my Xbox 360 using component cables every time i turn the HD switch on it jumps to a static mis-colored screen.i try to change it back from 720 to 480. is it just not...
U using a stantard tube tv,that why.It is an analog tv.It can't scan in high resolutions as ur Xbox require.That,why it reverse back to the resolution it can and able to scan the lower resolutions.
Dec 04, 2010 | Sharp 27F543 TV
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
DVI port on Sony Trinitron KV-32HS500 not standard.What fits it?
I've just recently connected my old 32" Sony KV-32HS510 to my HP G60 Laptop via an HDMI (laptop) to DVI HDTV port(TV) with a cable.
I'm running Windows Vista on my laptop with the nVidia software. Once I've plugged in the TV to the HDMI port, the software initializes (recognizes the TV) and then I can select it as my second 'monitor' in the nVidia control panel.
I found I had to tinker with the resolution settings in the nVidia program to find an optimal resolution where the sides of the screen weren't 'cut off' by the TV.. I finally ended up with the resolution 1152x768 (I believe). It might be different for everybody, as I'm told Vista might do things differently than XP... But you should be able to tinker with the resolution settings and adjust the screen size...
(hope this helps with the second post - above)
Feb 11, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Standard (CRT) Televisions
RCA plugs
I bought this kind of adapter, which allows me to use XBox, XBox 360, PS1, PS2, Gamecube, and N64.
Aug 07, 2008 | Zenith Z20A06D/X TV
No picture for game
get it checked out.
Apr 12, 2008 | Sylvania 6427FF TV
Game mode on tv
If you have a HDTV then you need to change the resolution to 720i or 720p to support the XBox 360 HD video. If you have a standard TV (non-HD) then you'll need to change your XBox 360's video settings to non-HD. The problem sounds like your mixing up HD video signal. I really need more info about your TV. Is it HD? Or regular?
Mar 25, 2008 | Symphonic ST420FF 20" TV
YPbPr inputs not working
Tacz, What video input# on the back of the TV is your component video?? Are you sure the TV is set to look at that video input#??? You may be looking at one of the composite video inputs as far as the TV is concerned and with nothing plugged in to that input the TV would naturally give the error message you indicated. Let me know.. Bill
Jun 11, 2007 | RCA 27F530T 27" TV
Zenith C27V22 27" TV Logo
151 people viewed this question
Top Zenith Standard (CRT) Televisions Experts
matt martin
matt martin
Anastasio Benjou
Are you a Zenith Standard (CRT) Television Expert? Answer questions, earn points and help others
