Try running undiluted white vinegar in system to clear out any calcium deposits clogging the line, and check for loose connections or leaks in the waterline on the hose part. There also may be dry solution from the previous use and that will clog too try running only hot water through it as you should rinse carpet after you shampoo it to keep dirt from sticking to you carpet.
Brushes on Hoover Steam Vac F7441-980 do not turn.Brush control on;drive pin present;filter intake...
(More)
Brushes on Hoover Steam Vac F7441-980 do not turn.Brush control on;drive pin present;filter intake clean; Drive mechanism doesn't appear to be turning. Also when spraying on cleaning solution, spray comes out in streeks rather than the width of nozzle. JBB
the upholstery attachment won't slide down to meet the opening for suction. Don't know how to attach...
(More)
the upholstery attachment won't slide down to meet the opening for suction. Don't know how to attach it.
