Question about Dell Inspiron 1000 Notebook
Removed a program, now No Audio on my computer.
I recently removed some programs on my computer because I got a message saying that I had low disk space, told me to delete unwanted programs. So i went to Add/remove programs and removed about 4 programs I thought were meaningless and then all of a sudden couldn't get Audio. My Itunes tells me there is a problem when I open it, I go to the tools and It won't let me move any of the Audio controls. What should I do so I can get my Audio back???
    Problem Solver:
  • 17 Answers
You probably deleted a program or service which itunes were dependent on.
Make a backup of your computer and reinstall the itunes software
Posted on Jan 01, 2008
Why my Toshiba Satekkite laptop won't reformat the hard drive?
Why are you trying to reformat the drive ? The entire operating system and all files will be destroyed if you do this. To reformat the drive requires an external program on a disk that would allow you to reinstall windows from scratch. Most Bios chips can do a reformat but accessing these low level programs is for pros only and varies widely from machine to machine. Unless you have a nasty Trojan, virus or worm that can't be removed any other way I would not do this. You will need a working copy of a boot disk to get the machine up and running after the reformat. Then you can reinstall the Operating System. If you had been successful in your reformat you would have found yourself with a DEAD MACHINE unless you had a boot disk ready.
May 25, 2014 | Toshiba Computers & Internet
Now my computer does not even recognize that I have a Labtec LCS-1060 speaker attached. In the Control panel, in sounds & audio devices, it says no audio device is connected. This failure happened only...
I would use system restore to put the lost stuff back onto your computer. Then if it puts back the unwanted software be more careful about removing it.
Nov 24, 2017 | Labtec Audio Players & Recorders
Why is my samsung pc freezing when I turn it on?
follow this steps and fix it. God bless you
A frozen computer might be a one-time occurrence, or it could be the sign of a more serious problem. If the computer continues to freeze up, there are several items that should be checked out. The first step to take is looking at any recently installed software. Programs such as freeware or shareware often contain malware that can damage the system. Even reputable software can contain a damaged file. Uninstall recently added programs and determine if that was the cause of the computer freezing up. To uninstall a program, go to the Control Panel from the Start Menu. Select "Add/Remove Programs" in Windows XP or earlier, or "Programs and Features" in Windows Vista. In the list of installed programs, select the one to be removed and click "Uninstall." Follow any prompts and restart the computer when the process is complete. Next, update and run both the antivirus program and spyware removal program installed on the computer, or use the link provided in resources. Check the Windows website and download any updates.
Finally, you will want to check the available space on the computer's hard drive and use the built-in error checking and cleaning tools. Go to "My Computer," right click "Local Disk (C:)" and click "Properties." On the "General" tab, make sure there is sufficient free space. The "Disk Cleanup" tool will free more space by deleting unnecessary files. Click the "Disk Cleanup" button to run the tool. On the "Tools" tab there are more tools that can solve the problems causing a computer to freeze up. The Error Checking Tool finds and corrects hard disk errors and the Defragmentation tool will reorganize system files, helping the computer run better.
Read more: http://www.ehow.com/how-does_4895756_troubleshooting-computer-freeze-up.html#ixzz2Zb7B2Sa6
Jul 20, 2013 | Audio Players & Recorders
Difficulty in booting or starting the computer
Determine if a new program was recently installed on your computer loadTOCNode(3, 'moreinformation'); If you recently removed a program or a Windows component from your computer by deleting it manually, related information that is still on your computer may be causing the problem. To remove the program or component, first reinstall it, and then use the Add or Remove Programs tool, or follow the manufacturer's instructions.
To remove a program from your computer, follow these steps:
  1. Click Start, click Control Panel, and then click Add or Remove Programs.
  2. In the list of programs, click the one that you want to remove, and then click Change/Remove.
  3. Click Yes when you are prompted with the question "Do you want to remove the program?"
If the program is not listed in the Add or Remove Programs tool, contact the manufacturer to obtain instructions for removing it.
Use the Last Known Good Configuration tool to restore the operation of Windows XP loadTOCNode(3, 'moreinformation'); If Windows does not start, try to restore operation of Windows XP by using the Last Known Good configuration. To do this, follow these steps:
  1. Start the computer, and then press the F8 key when Windows begins to start. The Windows Advanced Options menu appears.
  2. Use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then click OK.
  3. If a start menu appears, use the ARROW keys to select Microsoft Windows XP, and then click OK
Confirm that your CMOS/BIOS settings are correct loadTOCNode(3, 'moreinformation'); Confirm that your CMOS/BIOS settings are correct.
Warning This procedure may involve changing your CMOS settings and changing your BIOS. Incorrect changes to the BIOS of your computer can result in serious problems. Microsoft cannot guarantee that problems resulting from changes to your BIOS can be solved. Change your CMOS settings at your own risk. Incorrect or corrupted CMOS and BIOS settings can cause startup problems or shutdown problems.
Microsoft cannot provide specific instructions for changing your CMOS and BIOS settings because they are specific to your computer. For information about the correct CMOS and BIOS settings for your computer and how to check and change these settings, see your computer documentation or contact the manufacturer of your computer
Confirm that your hard disk or file system is not damaged loadTOCNode(3, 'moreinformation'); Confirm that your hard disk or file system is not damaged. Start your computer from the Windows XP CD-ROM, load Microsoft Recovery Console, and then use the Chkdsk command-line utility. This may solve your problem.
Jun 13, 2011 | Dell Inspiron 2200 Notebook
Whenever I switch on my laptop, I have a message on the screen saying: ''Operating system not found'' and I can't do anything else... The laptop is not responding anymore.
This error message could be caused by the laptop not detecting the hard drive.
Check the BIOS to see if it detects the hard disk
If not the hard disk may be faulty or needs reseating. If the hard disk is faulty it needs to be replaced and Windows installed on the new hard disk.
A virus program may have infected the computer and removed or changed some system files - in this case Windows needs to be repaired OR Windows re-installed - this is the best option.
Aug 25, 2010 | Acer Computers & Internet
Computer says not enough space in drive c have removed lots of programs but still says the same
Did you remove them or delete them? You will need to go to the control panel, select "uninstall programs" and click uninstall on the programs you want to remove.
you can also 'right click' on your C: drive and select 'disk clean up'.
This will scan your computer and help you get rid of a bunch of junk.
Also, empy your recycle bin.
May 19, 2010 | Acer Aspire One PC Notebook
Message when I started my computer
Your computer has the My Web Search toolbar. That is Malware and you need to remove it immediately. Restart your computer in Safe Mode and run all your security program scans. If you recently removed My Web Search then this reference was left in your startup folder. If this is the case I suggest you download and install this great free program CCleaner. http://www.ccleaner.com/ During the installation uncheck the Yahoo Toolbar or it will also be installed. Once you have it installed, click the Tools Tab and then the Startup tab. If you see the My Web Search toolbar left click it and then click Disable. Now click the Issues Tab and click Scan for Issues. Once it finishes, click Fix Issues. This will remove any remnants of My Web Search if you have removed the program. Post back if you need more assistance.
Dec 15, 2009 | Computers & Internet
Low disk space, how do i fix this problem,i have unistall some of the programs but stil having problem.when i restart the computer a pop up still diplay low disk space
low disk space because one of the drive is almost full it is having below 200MB space so this message will appear . i think so C drive is full just right click on the drive and make disk cleanup and in that select temporary internet files,temp files, recyclebin,compress old files and say ok it will remove all the files from u r computer which is not required finally space will get increased and message will not come
Jul 31, 2008 | Gateway Computers & Internet
Nero 6 missing files
Visit the nero support site and use the nero cleaning tool to make sure all traces of it are removed before a fresh install.
http://ww2.nero.com/enu/Support.html
Mar 01, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Dell Inspiron 1000 Notebook Logo
44 people viewed this question
Alun Cox
