PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
I have atoshiba satellit and when I sta...
By kjo373 on Oct 26, 2009
I have a toshiba satellite laptop and when I start it up it sometimes immediate or very shortly turns off. The ac power is connected and functioning perfectly
Best Solution
posted on Oct 26, 2009
Very Helpful)
stormwind13
Rank: Guru
Rating: 86%, 15 votes
It sounds like an overheating problem. If at any time a laptop overheats it will immediately shut off to prevent doing damage to itself. Is there dust clogged up in the vents? Do you hear a fan spinning internally? If not, its a possibility that your fan has completely burned out.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
bob_computer
Rank: Guru  Computer Hardware  Expert
Rating: 87%, 1260 votes
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I am looking for a TRUE desktop-replacement. I am looking for a quad-core min 4. GB of DDR3... (More)
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
Acer ASPIRE 5532, touchpad stoped working. I probably hit the Fn key or???
Answer
sd.ms pro.mmc.sm.xd drivers for HP Compaq laptop not work
Answer
number pad 0 will not work..it acts as a display window momitor
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
