Question about Proscan PS32500 32" TV
Power I turn it on and it clicks and goes off directly. It cycles this way twice. Took back off and fuse looks ok
  • John Jan 01, 2008
    what type of fuse do they have
    Sergeant:
    Champion:
  • 375 Answers
They have a 5amp fuse ,if the fuse was gone there would be no turn on at all.the set is cycling trying to fire but there is a fault stopping it ,it called three strikes your out, the set is made to do this, you require service.possible horizontal or power supply,problem. ask for a est,
Posted on Mar 20, 2008
Will not turn on power lead ok and power to unit and fuse appears ok
There might well be a fuse. Look around the area where the power cord goes in and around the transformer.
Jan 27, 2016 | Panasonic Audio Players & Recorders
NEC PX-42VP4DA
te power pack inside the tv has gone bad and needs replacement, contact manufacturer for parts.
Nov 25, 2007 | NEC 42VP4 42 in. EDTV-Ready Plasma...
Motor not turning at all. Water goes in and pumps
Since you say relay sounds are heard, it shows the command is OK. The power to the motor is not reaching. It could be relay contact problem.
If you have a option of only spin, try this option. If it works the motor is OK. Otherwise you have to trace the power line and test it through a electrical line tester.
Apr 01, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Have an old view sonic vx900 (~5yrs old). When you
Check the fuse on the inverter board and also verify it does have have 12vdc feeding the fuse. Worst case will be the lamps, power supply caps look OK?
Jan 18, 2010 | ViewSonic VX900 19" LCD Monitor
Yamaha rx v396
See page 9 for self test diagnostics. During power up there are checks primarily for the power supplies. If the conditions are not within specifications it will shut down, the second click to protect itself.
Power resistors in the power supplies perform as fuses and are known to fail.(they operate near there limits and from stress thermal cycles fail) These resistors need to be replaced with identical parts as they are part of the safety features of the amplifier.
Failed solder connection the result of thermal cycling are another common defect and are easily repaired.
Complete service manual in the link. If you are not technical provide the manual with the unit to a qualified technician for repair.
Hope this helps?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&cad=rja&uact=8&ved=0ahUKEwj5mtSNo-_UAhXpwFQKHU3FCR4QFghfMAk&url=http%3A%2F%2Fwww.vintageshifi.com%2Frepertoire-pdf%2Fpdf%2Ftelecharge.php%3Fpdf%3DYamaha-HTR-5230-5230-RDS-Service-Manual.pdf&usg=AFQjCNEMUjfVgZKgNtgwhVp-6PJtjEL_Hg
Jul 04, 2017 | Yamaha RX-V396 Receiver
Sanyo ds-25350 TV won't turn on, just clicks twice
Sanyo ds-25350 ? Not recognising that model number.
Sep 16, 2017 | Televison & Video
Sony Bravia 40 inches has a defect
More then likely your power supply failed. If you do not hear a click from the relay during the power up cycle then your power supply failed.
Jul 29, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
Ilo 2600 remote control code
I finally found a direct tv remote code for my Ilo television. It was 10171. Others you can try that were for Direct TV remote: 10154 10236 10463 10180 10178 10019 10177 10623 10179
Sep 09, 2006 | iLO 2600 Television
Proscan PS32500 32" TV Logo
96 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
