Whirlpool GEW9200L Electric Dryer
Problem for Whirlpool GEW9200L Electric Dryer
How hard is it to change a rear bearing in a ge
By susangay on Oct 26, 2009
how hard is it to change a rear bearing in a ge electric dryer
Model DCXR463EA1WW
Solution #1
posted on Oct 26, 2009
Not Rated)
haundi24
Rank: Guru
Rating: 89%, 32 votes
this could b a dificult job . be sure u disconect power . if u can remove front panel . u might b able to change it without removing the belt.order the rear bearing . this will give u a better idea what u r dealing with. pull drum forward at same time lifting front .not to far just enough to remove old bearing . might b a stop on end of bearing shaft. this is just rubber o ring remove it . now carfully realiange bearing with reciever. this can be tricky because belt is still on .
Was this helpful?
Yes
No
Solution #2
Not Rated)
milten1
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 90%, 489 votes
the most difficult part of this repair is having paitence.
the unit come aprat pretty easily but the knucklhead engineer at ge like us to bang knuckels...
http://www.appliancepartspros.com/part_details.aspx?part_id=2619300
the link above is for your part
no heres how to get it
depending on your model there wil be two screws going up from the ddor frame into the top
iof the are not there your top is hel don by two snap clips that can be pushed back with a putty knife between the fron panel and the top
once the top is of you will find twop screws on the inside edges holding on the front panal
once those are off the panel should lift up and off
becareful, of thee wire harness it should have a quick disconnect but not just roll the door to the side
once the door is out of the way
go under the tumbler and take a pic of the belt threading,,, or 2 , it can be confussing
lift the idler and take the blet off the motor
you should be able to lift the tumbler about 1/2in
and pull straiget out the front
from there ou should see how to replace the bearing, it only swapping out the clip,,,
make sure you do both the rear wall and the rear of the tumbler
hope this helps
have a great day
Was this helpful?
Yes
No
Popular Solutions for Whirlpool GEW9200L Electric
Questions and Unsolved Problems for Whirlpool GEW9200L Electric
Do you recommend Whirlpool GEW9200L Electric Dryer?
Answer
Answer
Whirlpool Dryer M # GEW9200lwg Permaturely Stops Drying After 20 Min's of an Setting.
Answer
need to replace heating coil. need info on which wires connect to which connection on coil. Duet... (More)
Answer
does not heat on any setting. opend and pulled out tons of lint but still does not heat. how does... (More)
Answer
my whirlpool dryer won't start and smell burnt. what could be the problem?
Answer
My Dryer won't start, the controls come on, I have power, the start button is pushed as normal, all... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool GEW9200L Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
