Question about HP PSC 2355 All-In-One InkJet Printer
Scanner wont scan
Printer works, copier works, but when I hit scan it states that the user interface files can not be found. Have done multiply reinstalls, hard uninstall, and various things but getting frustrated. Worked fine originally. Please help
Re: Scanner wont scan - HP PSC 2355 All-In-One InkJet Printer Printers & Copiers
Please you change warming lamp strip.
Posted on Jan 07, 2008
0 characters
3 Points
Xerox 3635mfp: On defining network scanning one needs to define the default file repository. This causes no problem but on pressing "Apply" (Via explorer interface to IP of printer) the system...
Xerox are aware of this problem and are working on a solution. I think the workaround is using capital letters for the administrator. Xerox software support should be able to help with this.
Jan 17, 2011 | Xerox Phaser 3635MFP/X Multifunction...
Unable to access scan folder of Toshiba e-Studio 232 scanner from windows 7 system
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
Nov 08, 2010 | Toshiba Printers & Copiers
HELLO. I have a client that have a IRC1021i and have the windows xp home edition . CAn the machine do the scanner by SMB to the computer (on sharing the folder it doesn t appears the security but i share...
1. create a file on the c: drive called scans point at it and right click share the file for everyone and allow other users to edit 2. type the ip address for the printer into internet explorer to access the remote user interface(RUI) 3. go to the address tab add a new file destination \\computername\filename or \\mycomputer\scans this is case sensitive. user must have a user log on name and a password or none of the above will work. goodluck
Nov 26, 2009 | Canon Printers & Copiers
HP LaserJet 3050 - can't scan to a pdf format
This is the only solution I found within the software. I went to the actual printer and hit the 'scan to' button. I selected SETUP from the menu options. It pulled up some software on my computer that shows the interface between the computer and the printer. I hit the NEW button. The next screen gave me some options and there was a checkbox option that said 'Show the TWAIN dialog after the scan...'. I checked that box. When I went to the next screen, it offered me PDF as an option and I made that my default. This process sets up a new menu option on your drop-down list when you scan. I named it 'PDF to computer' so I would know to pick it for pdfs. I tried to add it to the list of options available on the printer menu, but the new option I created disappeared after I hit UPDATE. But when I tried to scan something it was showing on my options list. When I tested it, it opened some software I never saw before and showed the image as it scanned, which I guess relates to the checkbox I marked. I've tried several times for hours at a time to find any kind of fix for this that didn't involve converting a file to pdf or loading a different software. This fix I found on my own just by hitting buttons on the printer. If you don't like this option, there is some free software out there that uses the scanner to create pdf's. I just didn't want to go that way.
Jul 16, 2009 | HP LaserJet 3050 All-In-One Printer
Scanner : could not find required user interface
I just turned off my firewall protection with CA security center (virus software) and my scanner came back to life. I've had nothing but problems with CA so it's back to Norton for me!
Mar 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Bizhub 250 Scan to searchable pdf
This copier scans as an image. The contents of this file are not searchable. The output type (as default) can be set by logging into the web interface of the machine. As for one- touches that are allready setup as tif, you would need to edit the one touch parameters to set the device to PDF. (image only)
Jan 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Hp scanner 3030
i have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
Aug 31, 2008 | HP LaserJet 3030 All-In-One Printer
Dell 964 scanner
First do your scan on Dell 964 scanner &printer. Scan to clipborad. You hear it scan but nothing happens on your computer. Go to control panel - scanners and cameras - scan profiles - find the document you have scanned, select it and click edit - click preview - in the left corner you will see in blue "How to scan a picture" click that, it will lead you to Windows Photo Gallery - there click on file and import from scanner of camera - it will scan there and your scanned pics will be in your picture folder :) Took me a while to figure it out :)
You can avoid all this and go directly to Windows Photo Gallery :)
May 26, 2008 | Dell Photo 964 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
116 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
