Question about Toshiba Satellite A75-S211 Notebook
I pulled apart my Toshiba Satellite A75 S211 to declog the heat sink. I did solve the problem and the system does not shut down suddenly any more.
I may have dislodged the connector (on the system board) for the LCD cable and do not get any vidoe display. If I connect the notebook to an external monitor it works just fine.
What do I do? Can I get a new connector? If yes, how do I install it on the system board?
Thanks in advance.
    Problem Solver:
  • 17 Answers
The LCD cable is a thin plastic film with visible copper traces?
If yes, you have to 'open' the connector before you put back the cable. These connectors come in 2 types: the 'pull' one and the 'flip' one.
You recognise the 'pull' one by the small flanges on the extreme ends of the connector. Use a small screwdriver or similar and pull out the connector in the direction of the LCD cable, push in the cable as far as it goes, then push the flanges back again.
If its the 'flip' one, you can open the front of the connector just like trunk of a car. Open it, push in the cable as far as it goes, and close it again.
If you already had done that, take out the cable and clean cable end + connector, then put it in again.
Posted on Jan 01, 2008
How to open toshiba satellite a75 to get to power connector
Click on the video link below for instructions on how to disassemble the A75, you may have to watch the video a couple of times or pause the video.
Feb 04, 2013 | Toshiba Satellite A75-S211 Notebook
My Toshiba A75-S211 overheats and shuts off.
That is common with Toshiba. Check to see if your fans are running. Also, there may be a lot of dust, hair, etc inside the laptop causing it to heat up. I recommend buying a laptop cooler. I got mine for $10 and I never have over heating problems anymore. Hope that helps:)
Dec 29, 2009 | Toshiba Satellite A75-S211 Notebook
My toshiba a75 cant connect to my lcd hdtv through s-video port or vga. i used an s-video to rca cable and a vga to rca cable but neither worked
Use the Fn key plus F5, F8 or F9 to change display to external
also you may have to change laptop's screen resolution to lower for lcd tv to display
Dec 22, 2009 | Toshiba Satellite A75-S211 Notebook
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
Nov 20, 2009 | Toshiba Satellite A75-S211 Notebook
My Toshiba A75 S211 shot off
the issue is likely thermal shutdown (it got to hot) listen to establish whether the fan(s) are working. you will need to take it apart to gain access to the fan area to clean out the dust and dirt.
Mar 24, 2009 | Toshiba Satellite A75-S211 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
    How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ... - 76k -
    Dec 31, 2008 | Toshiba Satellite A75-S211 Notebook
    Trying to find website that I have seen befoe that has instructions on how to open up the A75-S211
    Problem solved. Lap top stripped apart and that little line of dust got cleared out and now the laptop works as if new. Thanks to the website I posted above that shows how to safely dismantle the A75-S211.
    Oct 02, 2008 | Toshiba Satellite A75-S211 Notebook
    My screen is stuck with white vertical lines through a black background
    The A75 has on board video, so that can only be replace with a new motherboaed. However, it sounds like maybe the lcd cable is not secure either at the lcd, or the board. Try re-seating the cable. It's a 3 handed job to do the back of the lcd connection, but worth it if it fixes the problem.
    Hope that helps.
    good luck
    Nov 26, 2007 | Toshiba Satellite A75-S211 Notebook
    Toshiba Satellite A75-S211 Notebook Logo
    116 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
