Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Getting water dispenser to work when newly installed
I need to figure out how to get my water dispenser to work in a newly installed Kenmore Elite Countertop Depth side-by-side refrigerator? Any help? I don't have a user's manual.
  • 2 more comments
  • Doogee Jan 01, 2008
    I've done that.  I've checked the water supply and that is OK, also.  I don't know if the pump is working or not.  I got the frig turned on and cold, just no water or ice maker, yet.
    The unit is a floor model with no manual.  It's brand new, minus sitting on the floor of a Sears store for several months.  It was not plugged in to water, but they did have it turned on with lights on inside. I had a plumber hook it up today.  The work is code, copper 1/4 OD with several coils before the attachment for pulling it back to clean the unit in the future.  No kinks in the line.  There is plenty of water pressure and water is in the copper line.  I think there might be a problem from the point past the connection.  I can hear the motor running when I hold the water dispenser down to see if it will kick in.  I don't see a problem with the lines going into the door.  Just no water going into the unit past the point of connecting the copper to the unit.
    10-4!  I'll get a tech out here after tomorrow.  Happy New Year and thank you so much for helping out!
  • markh95 Aug 21, 2008
    bought a kenmore elite floor model two days ago...only some ice...a few cubes and water flows out of dispenser but does not run real fast. Should the water dispense slowly? How long to wait for the ice maker to work?
    Water supply is good.
  • 1,314 Answers
Yes if the water is hooked up and on dont laugh ive had it happen then hold the dispensor down about three 3-5 min or till water flows then to get all the air out of filter and water tank let me know if this does it
Posted on Dec 31, 2007
  • 1 more comment
  • robert samples Jan 01, 2008
    Ok check for kinks at the door where it goes to the dispenser up through the freezer door. There is no pump it works off your house pressure and you need at least 30 psi. You need to pull the kickplate and inspect the lines pull the water filter and inspect make sure it is not stopped up. It's just a little glitch somewhere we will find it just hang with me. How old is the unit? Did you hook up the water line yourself or has it always been there? If so did you use copper or pvc? Or did you use a saddle valve a screw on the supply line valve? That is suppose to puncture the pipe itself?
    ok roger that i would suggest changing the water valves as they may stick dry cycling how old or how long since you installed it if they let it sit with out turning the icemaker off the valves would keep cycling and wear them out their fault make them send a tech free of charge and dont let him leave till there is water in the door and the ice maker fills ok your right floor model does not void your warrenty copy me
    ill still be here till we get it fixed
My kenmore elite HE, smart pack is not dispensing the fabric softner? Can you help?
The softener water flow is clogged. You know, open the dispenser while it's filling in the final rinse and look over the softener dispenser. Is there water flowing?
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
We just replaced the water dispenser doesn't work.
Looks like water is frozen in the tank .Unplug refrige from wall socket ,leave freezer and food compartment doors open at least 12 hours to melt frozen tank..
Jan 18, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Water dispenser does not work
the volve for the water is might be bad need to be clean or replace the volve to the ice unit is with the water but they seperate units...
Dec 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigirator water dispenser issues
If you can get at the refrigerator compressor, vacuum off the dust that has accumulated on it. This may help.
Aug 30, 2009 | Whirlpool ED2FHEXN Side by Side...
Water has stopped coming out of the filtered water dispenser
I just had this same problem and finally figured it out. The water in the line was frozen because my freezer was turned to 6 (note on inside of freezer says recommended temp is 4) so I turned the freezer to 4 and the refrigerator to 3. Next day the water was flowing.
Hope this fixes yours,
Sherry in Pittsburgh
Jan 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite HE3 Washer fabric dispenser not working
This is usually just as simple as adjusting the syphone up and down. releveling your machine or cleaning the dispenser itself. when the water enters the dispenser gravity syphones the water out . nothing really machanical about it. unless the water is not filling up the cup enough to go above the max line. you can test it by putting water in the dispenser above the max line and adjusting the syphone cap up and down.this should grab a suction.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
165 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
