Sony Handycam DCR-TRV350 Digital-8 Digital Camcorder
Sony handycam CCD-TRV308
shared by 9 users
posted by TDB58 on Dec 31, 2007
I am having a problem when I turn on my vide o camera- plugged in or not that I get a c31:23 error message with an eject sign on the camera. This is the only problem code not listed in my information book and I don't know what it means. I have tried a different battery,letting the camera charge with no tape in the machine (thinking it was overheated) and nothing is helping. Any ideas?
I get a C:31:23 error message every time I turn on the camera. I have tried everything I know to do, including hitting the reset button and removing the tape. Anyone know of a solution? The camera cannot be used with this error. Thnx
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Posted by Guest on Apr 20, 2008
plays for about 5 minutes then screen scatters then shuts off
Posted by SteinyGirl on Mar 28, 2008
Having the same problem with the DCR_TRV530 error code of C:31:23 and checked wheel height as suggested. Didn't work. Other suggestions?
Posted by Salvin on Mar 25, 2008
what about the rubber whell that fell out of the camera?
Posted by Frankpaco on Mar 20, 2008
c:31:23 Digital Handycam Digital 8 DCR-TRV 510 Dear expert : Please could you help me in this matter.
What sould I do in order to put away the sound & c:31:23 and make to
return to normal work . (Sony Handycam DCR-TRV510 )
Sicerely yours
Frank
Posted by Guest on Mar 17, 2008
The camera fell off a shelf. A little rubber wheel was at the bottom of the tape, can't figure out where the wheel came from.
Solution #1
posted on Feb 08, 2008
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i'm having the same problem! anyone?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on sony handycam CCD-TRV308:
I don't want to Accept this solution
Solution #2
posted on Feb 22, 2008
Not Rated (0)
candyju
Rating: 70%, 3 votes
I was getting the same code and a dinging noise. I tried a cleaner and I tried letting the camera dry out...it wasn't wet! Neither worked. SOOO...Don't buy a cleaner. Look inside camcorder and make sure both reel turners are equal in height...they can slide down. Turn both of them...one of mine was down and also did not turn to make contact with tape. We got it to turn and the message C31:23 and the dinging quit. The stripes/bars also went away. Camera instantly worked like it used to. Good luck.
Comment posted on Apr 02, 2008
SteinyGirl, Did you also try turning the reels to make sure they are turning the tape? Hope this helps.
Candy
Thank You!
Can you Help with these Camcorders problems?
Sony Handycam DCR-TRV350 Digital-8 Digital...
For some reason my TRV-350 won't power up, even with the...
While opening the door of my camcorder, the plug was not...
How can i replaced the built in rechargeable battery of my...
hello how to copy my recorder tabe to my computer
it used to work when i used a movie maker to get it of...
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 16, 2008
code C: 31:23 with eject symbol shown. My digital reecorder will not function with tape in it.
What do I do?
Comment by Guest, posted on Feb 16, 2008
c31:23 CODE WITH EJECT SYMBOL . we all need help, please!
Comment by ChriSeattle, posted on Feb 09, 2008
Sony Mini DV recorder, same error code
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find Camcorder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
