Question about Refrigerators
Kenmore We have a Kenmore side by side Model Number 106-53242300. For the last 2 years there hasn' t been any water hooked to the appliance. We moved into a new house and now we have an accessible water line. Yesterday, we hooked u the water line. The ice maker is not making ice but the trays are filling with water. The water is then leaking out of the trays. I am filling up a 1 gallon conatiner with water (that has leaked) every few hours. Any suggestions?
  • 1,314 Answers
Sounds like your freezer isn't freezing lift up the wire arm on the ice maker to shut it off then put your finger where the ice cubes should be and if the water isn't frozen you may have a cooling problem listen to see if you hear the freezer fan running then look at the bottom of the freezer at the back wall where the vents are and see if they are blocked with frost and reply to me
Posted on Dec 31, 2007
Where is the water filter on a 1998 kenmore fridge
Here is where the confusion begins. When Kenmore says their model number, it is different than OEM numbers or original equipment manufacture's number's. Here is the deal with Sears when it comes to their model numbers. Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze Once you find that 363.235698 example you will be well on your way!
May 05, 2011 | Kenmore 52642 / 52644 / 52649 Side by Side...
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore 20422 leaves water and clothes soaked after spin cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Initial thoughts point to one of two places.
1. It's possible that your pump and/or hoses are clogged.
2. It is also possible that the "Motor coupler" between the motor and transmission is worn and cannot provide full power to the tub when agitating.
See the following illustrated descriptions of how to access the pump and motor coupler.
If either is bad or worn, they aren't all that expensive.
I doubt that the problem is the motor since the machine will agitate and spin.
Jan 06, 2010 | Kenmore 22422 Top Load Washer
Hi, you can purchase replacement part on amazon, here: Amazon com KENMORE ELITE INVENSYS CONTROL I hope this was helpful. Cheers
Apr 27, 2009 | Kenmore Refrigerators
Smart light not sensing darkness
there is a small pc board right there in the front panel it sontrols everthing from the light to the water and ice despensing . there are a lot of problems with this board and there not cheep from 65.00 to over 100.00 . i would wait untill another part of it fails ,and it will your water will go out ,or your ice . then you will be forced to replace it most only last 5 years ( new refrigerators are only lasting 7 to 10 years ) good luck
Mar 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore, f2
I can help but I need a model number
Kenmore are made by many different manufacturers of their appliances..
F2 error is most likely a oven sensor problem . your over sensor has to low or high Ohms or you Electromic oven control thinks it has to high of an Ohm reading. replace oven sensor and or control
let me know if this helps
Jun 06, 2008 | Ovens
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
233 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
