Question about Dryers
Hotpoint VTD00 Banging loudly once per rev
As above.
When I turn the drum by hand the bang seems to come from the right side ( as you look at it)
  • nuqHm Jan 01, 2008
    This morning I stripped the dryer down - yeah, rear mount/bearing/axle had broken.
    Crap for a machine only 18 months old.
    Bought a new one today in the sales - NOT a bloody Hotpoint!
  • Anonymous Jan 04, 2008
    Broken bearing - and shaft had cut into the metal of the frame of the back panel, before shearing completely.
    Not easy to repair - machine 26 months old, consigned to the scrap heap.
    Hotpoint cooker - same age, just packed up as well !!!
    Problem Solver:
  • 27 Answers
I think the bearing has gone in the drum !!!
Posted on Jan 01, 2008
  • Pete taylor
    Pete taylor Jan 01, 2008
    A cheaper option is to replace the whole dryer instead of just the drum..Sorry for the bad news
Hotpoint 1100 banging very loud when spinning,can thi be repaired please?
the chances are its the bairings in the drum that have gone,can you move the drum towards and away from the door easily? if so its prob the bairns,just like on a bike wheel they make the drum spin free but if they break it wobbles out of true causing problems and loud noise
Mar 19, 2013 | Hotpoint Washing Machines
WMA30 Front loader
when a machine gets old it is always normal for the vibration and banging to occur, then, after the vibration it settled down smoothly.this is due to worn fan belt .bearings worn out and the preasure on the dont get alarm .but you will soon have to replace the washer as the banging and the vibration will get worse eventually.or change the fan belt.and replace bearings.which can be done by a qualified personel.good luck.
Jun 09, 2007 | Hotpoint WMA30 Front Load Washer
Drum not turning properly
Sounds serious! If the drum is floppy, it probably means bearings on rear shaft.Or there may be something caught between the tank and the wash basket.Check for wire or similar caught in holes in was basket. Try turning the was basket slowly by hand to see if the banging happens at the same place......Nomess
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Machine banging when in fast spin
if the noise is coming from inside the drum then it will be the bear ings if this machine is less than 3years old then this is what bust hotpoint they changed the bearing setup and put a spring on it which its the spring that is the complete failure u need to take the complete drum out strip this put the new bearing set in but without the spring this wil put at least 2-3years on the bearings its a big job and costs about £120 to fix u r accually better off buying a completely different washer no good are hotpoints anymore m8
Jan 26, 2008 | Hotpoint First Edition FEW12 Front Load...
Dryers Logo
271 people viewed this question
Top Dryers Experts
