Question about Toshiba TP43H60 43" Television
Toshiba TP43H60 no pic, no sound, black screen, flashing red light, clicks like it is starting up but doesn't
Re: toshiba TP43H60
If you can change the channel, it might fix the problem. Mine was doing the same thing. After I hooked it up to a coax, I changed the channel, it was on #1 once I got it to channel 3 every thing came back. Try It.
Posted on Apr 08, 2008
  • Toshiba Master
  • 8,617 Answers
Re: toshiba TP43H60
You need to trouble shoot your power supply. There is a toshiba power supply and shutdown circuit troubleshooter available for your model at the following link for 10.99 They will also provide free unlimited assistance after you purchase a manual. They will either mail it or email it. If you'd like it emailed you must return to the site after purchase and click on the contact link and request that they email it along with the info on how to obtain the free support. just provide the email address you want it sent to. Hers the link.
Posted on Jan 17, 2008
0 characters
3 Points
Toshiba Cinemax Series HD Black screen - no sound
The red light flashing is usually the set detecting a short, to know if I can or cannot help I need to know the model number of this Toshiba.
Dec 16, 2012 | Projection Televisions
Toshiba TP43h60 - Wondering what the dials are for
You are describing the MASTER SCREEN/ FOCUS CONTROL BLOCK---black with six controls--three are red, green and blue focus--the other three are screen controls--red, green and blue--- the screens are adjusted so with the color off you have normal brightness and a black and white picture--
They have nothing to do with any Convergence problem and unless they have been tampered with rarely need to be adjusted---
I am here to help people.
Oct 09, 2009 | Toshiba TP43H60 43" Television
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
I have a TP43H60 toshiba and the power light continues to blink red and there is no picture or sound. I can't turn it off either unless I unplug it??
You have blown one of the pecos fuses, probably the f850 or f852, you can test them with the power unpluggrd and with an ohm meter. Replace them with only the recommended amps fuse. Your set is going into standby, because of the blown fuse.
Jan 28, 2009 | Toshiba TP43H60 43" Television
Toshiba big screen tv. tp43h60
Good Day;
I would suspect the convergence IC's, to confirm this unplug the convergence yoke, all three. If TV comes on IC's are bad. Also, check the little green pico fuses. Good Luck, big IRISH.
Nov 10, 2008 | Toshiba TP43H60 43" Television
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60
I have the same issue with my toshiba 32" circa 2000. I am told that it is a burned out diode of some sort and it is a horrendous repair job.
Aug 27, 2007 | Toshiba TP43H60 43" Television
Toshiba tp43h60
You have a bad regulator IC or something in the seweep power supply is blow out. if you can read a schematic, i suggest you get one to troubleshoot the solid state circuits in this TV set. if you do not have any solid state repair experience or no electronic background, play it safe and call in a pro to assist you in the repair of this TV set. Good Luck.
Mar 17, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60 43" Television Logo
96 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
