Universal Remote Control MX-3000 LCD Touchscreen Remote Control
Dynamic entertainment system mx3000
posted by h82bl8 on Dec 31, 2007
my bottom button in the square around the select button does not push in like the others. With the others - I can hear a little click sound. With the bottom one - it won't push in or click. It will work - just not very good. You have to hit it just right. I believe something is under it(some kind of spill?) I'm wondering if I can pry that square off around the select button and clean it out at the bottom??
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 01, 2008
Not Rated (0)
jessee007
Rank:Wiz Wiz
Rating: 79%, 193 votes
remove the batterys and look for 1 to 4 screw holes. have a thin bladed knife to push in on the seam and to pry open. I start at the battery box side.. once apart you might have 1 or 2 small screws holding the curcit board down and some prongs to . Remove the srews and push the prongs to the side and pull off the board . you will be at the rubber button side. clean as much as possible. notice the inside of the buttons. you can use a pencil to draw on the inside to act as a conductor for the bad buttons that are worn
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dynamic entertainment system mx3000:
I don't want to Accept this solution
Can you Help with these Remote Controls problems?
Remote Controls
I have a JVC TV and the remote is a Phillips Universal...
Remote Controls
My TV's remote control's PIP does't work! I had my RCA for...
Universal Remote Control MX-3000 LCD...
live 75 miles n of seattle, do you know the closest...
Am a Fix Ya customer still trying to either replace faulty...
Hello, wondering if you found someone to program your...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find Remote Control Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
