I can't transfer images from my canon 40d to my computer. I think the place where the plug the cable into the camera has been damaged, it feels loose.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Canon 40d Autofocus confirmation light damage
1 I suppose this is related to hardware problem.
2 May be the focusing screen is misaligned somehow.
SOURCE: Split images
use good antivirus with updates and then transfer ur images and cd write it
half middle pic is due to speed of ur pc and viruses
SOURCE: The AF on my Canon 40D seems to be malfunctioning.
Remove the lens and look at the metal contacts on both the lens and the camera. If these are dirty or corroded it could be the problem.
Here are some instructions on cleaning the contacts:
http://www.ehow.com/how_5089134_clean-camera-lens-contacts.html
Your local camera store can also do this for you as you need to be careful not to damage the sensor or mirror in the camera.
If this still does not help it can be a problem with the lens or the camera and you need to send it to the manufacturer or an authorized repair center.
Hope this helps,
-Tor
