Question about HP OfficeJet r40 InkJet Printer
Hp officejet r40 cartridge carriage blocked
Printer was "leaking" ink. Found on the right side "huge" deposits of ink. Tried
cleaning out ink (what a mess) after talking out gobbes of ink, I hooked printer
back up to pc and I get the message, "cartridge carriage blocked" telling me
to close cartridge covers, turn off printer than turn back on. No go! I can turn
printer off and open the latch to the cartridges and move the container with
the cartridges back and forth, but will not work when printer is turned on. I can
not see anything blocking the cartridge carriage. Now, did I move something
inside and I was cleaning the ink deposits? Is it time to take to repair shop?
thanks Max
email: baejake@cox.net
  • sroysr May 26, 2008
    read out says carriage blocked, etc., btu i can't see anything blocking it.
  • Anonymous Feb 09, 2009
    Same problem. Haven't cleaned out the ink dump station on this printer. That is an awful messy job that I've done on other HP printers. This is a design flaw in my opinion. It they have to purge the cartridges to keep them from plugging they should at least design the unit to enable cleaning the dump continer. I suspect that the whold ink dumping strategy is designed to sell more ink.
  • 4 Answers
Not sure about r40's, but look here about the leaking ink solution for G85's and DJ900's: http://www.fixyourownprinter.com/forums/inkjet/22399
There is a guy named BERT who is a master a fixing HP units, and his email can be found in the above mentioned forum note.
Posted on Jan 06, 2008
Carriage Jam for HP 6210 all in one printer
It a service faulty. you can batter replace it solved the problem.
Jun 12, 2013 | HP OfficeJet 6210 All-In-One InkJet...
I put a yellow ink cartridge in printer and it is new but the printer is saying yellow cartridge is empty so i am unable to print anything what do i do
Did you remove the plastic Seal undernith your ink Catridge, also check for any dry ink deposites where the yellow catridge sits in the catridge carriage box, if present use an alcohol cleaning pad to clean the carriage and re-install and verify.
Dec 03, 2010 | HP Officejet 6500 Wireless All-in-One...
I have a hp printer officejet J5780 All imn one.
I have found this model has a bad buildup of black ink in the right carriage bay chamber. With the printer on, open the carriage access lid and pull the power cord before the cartridge carriage can move all the way to the right side. Then gently push back the cartridge holder on the right if it's in your view, so you can see if there is a collection of black ink. The tri-color cartridge has a preventive bracket that doesn't seem to build as much as the black one. Anyway, once you've cleared any dripped ink cones or globs, plug the printer back in, turn it on, and if you get the Carriage Jam error one more time, press OK, and it should work well if that was the block on the carriage movement. I hope this helps you to get printing again.
May 04, 2010 | HP Officejet J5780 All-In-One InkJet...
Where is the carrriage located on my hp 7310 officejet printer?
The carriage is the unit that holds your ink cartridges, usually parked on the right side. When you have carriage stall or carriage jam you usually need to clean the clear plastic strip that runs across behind the carriage assembly, and make sure there are no scraps stopping the travel of the carriage.
Dec 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How do you change the ink carterage in an hp officejet 5610v all-in-one?
Hello !
To change the ink cartridge(s) in your printer,
Open the print-carriage access door by pulling it forward.
The print carriage moves to the far right side of the HP All-in-One.
Remove the cartridge.
Take the new cartridge from the package.
Remove the strip from the cartridge without touching the metal back.
Insert the cartridge.
Hope this helps.
Oct 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Power button is blinking and Carriage is stalled
there are two cartridge one is the ink cartridge which can be found on the left side of the printer (in front)and the other one is the head cartridge that can be found on the right side if you will open the printer cover that is the carriage check it if the flip cover is lock properly then try to reinsert the head cartridge..
Sep 10, 2009 | HP OfficeJet Pro K5400dn OfficeJet Pro...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Mar 06, 2009 | HP DeskJet 930c InkJet Printer
How to change ink cartridge on a HP Officejet R40
Hai
Please click on this link, and you will find the instructions with Pictures to change the Cartridges
Change the INK Cartridges
Thanks
Riz
May 30, 2008 | HP OfficeJet r40 InkJet Printer
HP OfficeJet r40 InkJet Printer Logo
336 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
