Question about Dell Latitude D600 Notebook
Missing a keytop
Where do i find keytops
    Sergeant:
  • 263 Answers
Ebay you can find everyting
Posted on Jan 01, 2008
Service department
They don't print, could be typewheel, being they are in a row, most
likly in the keyboard. Keyboard can be taken apart and cleaned. pretty big job. But contacts can be cleaned, some times light spray of electronics cleaner that will not harm plastics can be used. Test on plastic before you spray on key board. remove keytop prys off and slight spray down shaft that holds the keytop. Move keyswitch up and down to get into the contacts and see if it works. Good luck...
Aug 04, 2014 | Nakajima AE-800 Electronic Typewriter
Ax-20
Remove keytop and see if anything is under. Some have a soring under keytop, others use a "bubble" under the keytop. Keyboard can come apart and cleaned if you know how, covers have to come off and keyboard removed, also try just blowing out with canned air.With keytop removed see if you can pull the key up and down, if you can then the problem is with the contact on the board under the keytop...
Apr 08, 2014 | Office Equipment & Supplies
How to activate malfunction keyboard of Letter D?
If both the upper and lower case don't work you have a keyboard problem. If one works you need a print wheel.
DickyO
Oct 23, 2013 | Brother GX-6750 Typewriter
Cleaning keyboard
No they are not. Just turn your key board upside down and give it a shake until all debris is out then wipe keyboard very gently with soft cloth. No water.
Sep 28, 2013 | Dell rt7d20 -...
I need the letter key M/m for the Swintec 1146 CM model can you help me replace it?
If you are saying that the "M" key dosen't enter you can try this. Gently Pry the keytop off, Make a small paper spit ball, push it down the hole below the keytop, reinsert the keytop.
If one dosen't do it try two. If this doden't work you will have to replace the contact pad inside the keyboard.
DickyO
Dec 05, 2010 | Swintec Office Equipment & Supplies
Quiero linpiar toda mi computadora
Hola, la mejor manera limpiar el interior de su computadora y entre las llaves est? con aire conservado. Usted puede limpiar los keytops con un pa?o h?medo. Respetos, Farmerbear
Sep 03, 2010 | Computers & Internet
The H, I, O and L keytop markings are worn away
i can give you a sensible suggestion; on a little piece of paper write out the name of the alphabet on it and stick it on the right key on your keyboard, till you finish assigning a key for the faded keys. Good luck
Aug 12, 2009 | Microsoft Natural Ergonomic 4000
Left shift key wont go back on
Given that replacement keyboards are not all that horrendously expensive you could actually replace the keyboard if it comes to it eventually.
However, what we did in the old days when replacing keys with worn out lettering was hold a soldering iron on the metal finger the keytop attaches to until the metal of the finger is very hot. Hot enough to push the keytop back on. While you push the keytop down onto the metal finger hold and press firmly for about 1 minute and then release. That should meld the two together if its going to happen at all. Leave it untouched for at least 30 minutes to ensure a firm bond.
This doesn't mean this will be an end all solution to your problem.
Because you mention the broken plastic piece, this mean this keytop may come loose or off again at some time in the future.
If you have tried and used super glue already be prepared for a smoke stench that will come off while you hold the soldering iron on the key finger. Burning super glue is how CSI techs reveal finger prints. That doesn't mean its very safe to breath. So, take some ventilation precautions while you do this. Essentially, do not breath the smoke directly, it will rise quicly on its own until its burned off.
Best of luck,
Worldvet
Jan 05, 2009 | Acer Aspire 5315 Notebook
Broken Button
The trip spring under the return keytop needs replacement. Lawrence
Jul 24, 2008 | Lexmark Wheelwriter 1000 Typewriter
How do i reboot a hp pavillion
in hp you will not get any switch for restart.you have to restart from the operating system only
Jun 25, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
24 people viewed this question
Alun Cox
