Question about Avaya Lucent Partner 616 Phone
Static in phones
I have a Lucent Partner 103H phone system I dial tone from my provider but not on the phone after power went out in building. I can dial out and I can receive calls but just static in ear piece
  • Anonymous Mar 17, 2014
    My phone have no power and all the calls that I received went straight to voice mail. do you have any solution to my problem?
Static on Partner systems is not too uncommon and more likely as the system ages. These systems use relays (electric switches) to connect to outside lines and extensions. The static is usually from a faulty relay, but sadly these are not really repairable by end users. A power outage is sometimes associated with spikes - short high voltage conditions that occur as the power comes back on. Any vulnerable component may fail at that time. The solution is to replace the bad circuit pack. These are available used - just use your search engine. Prevention can be as easy as installing a good surge and spike protector power strip between the system and the outlet.
Posted on Feb 08, 2008
What analog terminal adapter do I use with AVAYA Model 103H? I want to add a polycom phone to our system & we need to know what kind of adapter to use. Thanks!
On Partner systems the port works for both digital and analog telephones.So if you have a digital port in your conference room for your Partner phone you can unplug the phone and plug in your polycom.
Nov 16, 2010 | Avaya Lucent Partner 616 Phone
Lucent Partner phone speed dial
At ext 10 or 11, press feature 00
then feature and 600 or whatever code you want
then enter the number as you would dial it.
when done, enter feature 00 to get out of programming.
May 10, 2010 | Avaya Lucent Partner 616 Phone
Lucent Partner 18D cant fully reboot itself
That one doesn't sound too good.
You could perform a reset through programming which should clear the scratch pad.
Thats done by entering programming on either ext. 10 or 11
Press feature 00 then the left hand intercom twice.
Next enter # 728, the display should say reset save all then reboot the system.If the problem is still there, then the processor is malfunctioning and will need to be replaced.
Dec 04, 2009 | Avaya Corded Phone avaparp18d
I have a Lucent model 103H. I no longer get a dial tone when I push the line buttons. I only get static. I replaced the two AAA batteries yet I can still not dial out or receive incoming calls. Do you have...
hmmm .. the lucent 103h is called a "partner 5 slot (carrier) chassis for partner internal phone systems .... used in business usually for multiple phones... unless you have a home phone by that same name .. if you do have a "partner" system then lucent repairs those for about $65 ... check the line before considering repair ... if you have a single standard phone that just happens to have the same name .. then you may have a damaged telephone line .. you can test that by unplugging this phone and temproarily plugging in another .. if it works then there is likely damage to your original phone .. usually its lightning surge protectors that fail (due to a nearby llightning hit) ...if a second phone doesnt work then there is usually a service jack near where the phone line comes into the house .. you can plug in there .. if the phone is bad there also then its an outside maintainence repair job .. thats free from the telephone company .. if the test phone works at that test jack then its often your responsibility to arrange inside line repair .. unless you have an inside line repair contract the telephone company may charge for inside repairs .... your phone company can talk you thru using the service jack .. you would first disconnect the rest of the house by removing a connector from the service jack then you would plug in a standard phone to that jack .. that makes sure the problem is either inside or outside .. if your phone happens to be chordless then there is more things to consider .. the handset and base have to develop a relationship in order to work properly ... that relationship can be lost in a power failure and must be reestablished .. usually thats done by removing power from the base for a minute then connecting it again .. so there are a lot of possibilities depending on what type phone you have ...
Aug 18, 2009 | Avaya Lands Phones
Lucent Avaya Partner System Lost access to Voicemail
Obviously you lost your programming. Question is whether the unit is operational. Best thing to do is contact your local Avaya Business Partner for a repair.
If you tell me your location, I can recommend one.
Apr 01, 2009 | AT&T Lucent Merlin SP 34 Phone
Using intercom on Lucent partner phones
A Partner is a pretty simple system and the phones are probably all in a single calling group. Your extensions are numbered from 10 to whatever, so at the least you can grab a phone, press the intercom button and dial 0 or 10. It will ring the main phone.
From there, you can start dialing 11,12,13 etc and build your directory. IIRC pressing * in front of the number turns it into a handsfree call. Now, here's where you get to see what kind of installation you have :-) Press intercom and dial *71. With luck, every idle phone will have paging. (71 will ring every phone btw).
This does require programming and an extension can be either in or out of a group.
I do have a basic Partner ACS manual on my website. http://www.public.carl.airpost.net/Partner_ACS.pdf
The display phone users manual in in the document. Page 179 starts chapter 6, a 30 page guide to the phones.
Carl
Jan 11, 2009 | Avaya Corded Phone avaparp18d
Cant get dial tone
Know that they need to be plugged into a Partner phone system.
What are you plugging them into?
Carl
Jul 30, 2008 | AT&T Lucent MLS-12D Phone
No dial tone
do you still have a problem?
Jun 17, 2008 | AT&T Lucent MLS-12D Phone
I am trying to add phones to my Lucent / AT&T Partner system but they do not have dial tone.
No, you will need to have the company come back and "liven" up the jacks.
Sometimes there are not enough ports of the phone system to connect all the wall jacks to the system. So it is possible that you have to expand your system.
Dec 14, 2007 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
325 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
