Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Kodak easy share z712is will not turn on/...
By shansieg on Oct 26, 2009
This is the second kodak easy share z712is I have owned in less than a year. The first one was dropped about three days into owning it, and I thought the issue I had when trying to open/turn on the camera. So figuring that it was because it fell, I got a new one thinking that the dropping caused the issue. Now about six months later, and with no such dropping of the camera, I am having the same issue again. I have tried changing batteries, using only Kodak ones, using Duracell, using rechargable, and all have yielded the same thing--nothing. The zoom lens will emerge as if trying to turn on, and then go back in, but not all the way and the camera never turns fully on. I am COMPLETELY frustrated with this issue and am thinking about getting another brand of camera altogether, for the first time in my life. Anyone have any ideas?
Solution #1
posted on Oct 30, 2009
Not Rated)
webb243
Rank: Guide
Rating: 80%, 5 votes
I just fixed my camera that had the exact same problem. To take the back plastic off it was fairly straight forward, remove all the visible black screws on the outside of case, remove the plastic cover on left side, exposing 2 silver screws, remove, then open the a/v cover and remove the screw and the entire door assemble comes out. With a little bit of wiggling, the back half of the plastic case will come off. Now, the tricky part is figuring out how to take the front half of the plastic off. The front plastic piece is held on by 3 screws, 1 to the left of the lcd display, 1 to the top right of the lcd and the third is hidden behind the screen (they're recessed in 1/4" holes and you can't really see the screws). To get to the third, you just have to carefully pop the screen off (held by tension) and you will see the hole where the third screw is. Remove those and you can take the front piece off (you have to lift up on the bottom by the docking port to get around it). You may lose the screws, but just shake and eventually they'll fall out. For me there was a metal clip thing with a piece of tape on it that was scrunched up at the bottom of the lens in the gears. I removed it, pulled the lens completely out and that solved my issue (I just put the plastic back on w/out the screws to test). Don't know if that is what your case is, but if you want to keep the camera, give it a try.
Was this helpful?
Yes
No
Solution #2
posted on Oct 26, 2009
Not Rated)
faxmando
Rank: Guide
Rating: 75%, 1 votes
We should form a 'Club of Kodak Z712IS Owners' :)
I have the exact same camera for well over a year now.
It's hard to imagine you'd be so lucky as to get 2 cameras, back-to-back, with the same problem.
The only *usable* battery for this camera is the Lithium type, such as the Kodak CRV3
If you have a meter check the voltage; it should be about 3.5 V
The other battery brand, Energizer Lithium 7X, gave me near 500 shots. These should measure 1.8V each, and the camera stops working when the voltage falls to 1.5V
But they are both pricey!
The economical solution is rechargeables, but forget the regular ones. Fully charged they show not more than 1.3V
The only *usable* rechargeables are the Li-Ion type. Mostly rated at 1,600mAh
They normally show 4.0 to 4.2V when fully charged; mine show 4.2V and my Kodak 712IS is happy.
Was this helpful?
Yes
No
Solution #3
Not Rated)
typrice
Rank: Wiz  Cameras & Camcorders  Expert
Rating: 79%, 893 votes
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
best for close up pictures for ebay
Answer
sony digital camera charger
Answer
pentax optio e35 digital camera when i went flat lens stuck out after new batteries fitted amera... (More)
Answer
My camera does not focus, Picture is not clear, and it will turn off by it self when it is trying... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Digital Cameras:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
