Question about Hotpoint RVM1435 Microwave Oven
Won't heat. Everything else works.
My Hotpoint RVM1435BD microwave doesn't heat but the keypad and everything else works fine. I checked the internal fuse and it is also OK. Anything else I can do?
  • Anonymous Mar 09, 2008
    same here just wont heat everything else works fine??? Tom
  • 579 Answers
Magnatron is suspect. Need to put a voltmeter on it and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Posted on Dec 31, 2007
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
GE eterna spacemaker microwave won't heat
The problem is a magnetron, "heart of the system" or the inverter board, "if 7 years old or less" and possibly the keypad control board, all of these items are not cheap and lethal voltages are present.
May 05, 2012 | GE Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Oct 04, 2011 | Microwave Ovens
Microwave does not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfgf
May 15, 2010 | Hotpoint RVM1635 Microwave Oven
Microwave has power turn table works won't heat hotpoint model rvm1435bd 001
Check your door satey interlock switches.
If these switches fail (do you open the door while the machine is cooking?), the microwave doesnt know the door is shut and will not turn on the magnatron.
If you need more help, let me know.
a
Sep 27, 2009 | Hotpoint Microwave Ovens
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
At times some butons don't work
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | Hotpoint RVM1425 Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
266 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
