Mitsubishi WS-55513 55 in. Rear Projection HDTV Television
Problem for Mitsubishi WS-55513 55 in. Rear Projection HDTV Television
TV's picture and sound goes off. Have to turn off
By franksterp69 on Oct 25, 2009
TV's picture and sound goes off. Have to turn off and back on then it work's for awhile then it happens again
Comments:
Oct 26, 2009
- It goes 1 blink then 2 blinks, Mitsubishi WS55513 HDTV work fine for hours then picture and sound goes off have to turn tv off then back on then it worked for a few hours, now as soon as you turn it off and back on the picture and sound goes off in 5 to 10 seconds. Could you please help me? Is it worth getting it fixed?
Oct 26, 2009
- No I don't know what glycol is. Is my TV worth fixing or should I just get another one. That's the first problem I've had with it since I had it. I think about 5 years. thank you
Oct 27, 2009
- no I don't see anything leaking.
Oct 27, 2009
- Thank you so much for your time
Solution #1
posted on Nov 25, 2009
Not Rated)
Dnor350
Rank: Master
Rating: 0%, 0 votes
On the signal board there is 4 surface mount transistors. There is oneright by the input board (BA09), i would check the corresponding capsand diodes close to it also. I would replace all of the 4 transistors.If this SMT starts to go you will see wavy lines in your picture thanit will go away in 3 min or so and get worse over time until no pictureis seen. When it totally fails you will have no inputs what soever butyou will have an OSD screen and when you choose DTV you will get ascrolling picture.
Was this helpful?
Yes
No
Solution #2
posted on Oct 26, 2009
Not Rated)
dominicksans
Rank: Apprentice
Rating: 0%, 0 votes
I have the same issue with my WS55613, started out doing it every now and then, you could turn it of and back on and it was good to go for days or weeks, slowly it has become worse, last night it went out for good... picture and sound comes on for 5 seconds tops, then goes off... Error Code 12....
Was this helpful?
Yes
No
Solution #3
Not Rated)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 904 votes
The model you have selected should have a self check feature: when turns off and the green power light goes off:
ON THE FRONT OF THE SET PRESS AND HOLD BOTH MENU AND INPUT together for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example: 2 blinks, a pause and 2 blinks--it will repeat the code about 10 times.
error codes for this set:
1, then 2 no error detected
2, then 1 X-ray protection
2, then 2 short protection
2, then 3 deflection circuit problem
2, then 4 vertical deflection problem
2, then 2 is the most common and easiest to fix.
Let me know what you find and if 2,2 I have detailed instructions for repairing that kind of trouble.
I am here to help people.
SD TECH
Comments:
Oct 26, 2009
- IF 1, then 2 blinks it means whatever is wrong it is not triggering an error code.
I gather the amount of time it will play has been getting shorter and shorter?
Do you know what Glycol is?
SD TECH
Oct 26, 2009
- Ok---some history about Mitsubishi:
Some of their sets had problems related to Glycol. Each of the 3 picture tubes this set uses has a sealed area right on the face of each tube with Glycol to keep the face of the tube cool. Some of their sets had problems with the seals leaking Glycol out and dripping down onto one or more of the circuit boards----this stuff is like antifreeze, only much more concentrated and toxic.
There is a easy way to look for this: Remove the front speaker grill (it pulls out) and remove the inspection plate behind it-----inside the set from left to right you will see 3 large circuit boards--if there are any leaks damage should be seen in the first 3 inches or so from the front of either the middle board which is tan in color----or the right board which is dark green in color.
What you are looking for is either any sign of liquid (there only needs to be a small amount) or on the green board some kind of white residue or discoloration on soldered parts-----looks like white powder when it dries
IF YOU SEE ANY ACTUAL LIQUID, DO NOT TOUCH IT WITH YOUR HAND! YOU WILL ABSORB IT INTO YOU BODY AND THIS STUFF IS VERY TOXIC----this is the reason they do not allow these types of sets to be put in the landfill anymore.
You have to look very carefully for anything that is even slightly discolored---this stuff is also conductive---means if it gets across parts or leads for parts it creates a short.
Let me know what you find----if Glycol damage I would not suggest attempting to repair it--the real problem there is someone also has (if they can repair the damage it has done) to locate which tube or tubes is leaking and remove, drain, reseal and reinstall them back in the set------MAJOR LABOR.
IF YOU NEED ANY ADVICE OR HAVE QUESTIONS LET ME KNOW.
REGARDS, SD TECH
Oct 27, 2009
- ok, I usually do not make a suggestion like this but I think you at this point in time only have two real choices----
Either have a shop pick it up and see if they can find the trouble--I doubt it will be fixed in your home because any good tech will look to see if it has a error code----Considering costs just to have it sent into a shop it may or may not be worth fixing. Keep in mind, if the convergence circuit has never been repaired you could get your current problem fixed and then at any moment it could need the convergence circuit repaired---double trouble.
The only other option is to replace it. If you buy a Plasma or LCD set make sure you get at least a 3 year extended warranty and 5 years if you can--those sets have a lot more problems; I have seen people who paid 1500 for a plasma and did not buy a warranty beyond the 1 year---anything goes wrong on one of those boards and labor can easily be 50-70% of what the set cost.
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55513 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55513 55 in.
Do you recommend Mitsubishi WS-55513 55 in. Rear Projection HDTV Television?
Answer
Answer
Light blinks and System reset does not reset, therefore the tv will not turn on. I have unplugged... (More)
Answer
Only showing in black and white - how do I get it to be color?
Answer
want to control pip on ws55311 mitsubishi tv using time warner at8560 remote .cant seem to find the... (More)
Answer
TV is 5 years old [3 weeks out of warranty :-( ] Apparently had a brief power outage, tv is plugged... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55513 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
